Go to Post Mentors build mentors. - Siri [more]
Unread 19-01-2006, 21:27
VEN's Avatar
VEN VEN is offline
The future isn't what it used to be
AKA: Volodymyr
VRC #0478 (Mustang Robotics)
VEN is a name known to allVEN is a name known to allVEN is a name known to allVEN is a name known to allVEN is a name known to allVEN is a name known to all
Send a message via MSN to VEN
Inventor 9 Help
We downloaded this file:
http://www.ifirobotics.com/docs/driv...-inventor8.zip
and opened it in Inventor 9 in order to assemble the chassis. When we tried to insert bolts into the rail holes using constraints it would give out this message "Constraint was placed to geometry which no longer exists"
What could be the problem?
Thanks
Unread 19-01-2006, 21:48
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Inventor 9 Help
Have you tried hitting the "update" button first?
Unread 20-01-2006, 18:17
VEN's Avatar
VEN VEN is offline
AKA: Volodymyr
Re: Inventor 9 Help
Yes it did not help.
I have one more question. Can not find the way to reduce the length of the part (the bamper) downloaded from the ifirobotics.com.
Thanks for the help.
Unread 20-01-2006, 21:15
bjimster1's Avatar
bjimster1 bjimster1 is offline
AKA: Jimmy Bourne
FRC #1029 (Wolvcats)
bjimster1 is just really nicebjimster1 is just really nicebjimster1 is just really nicebjimster1 is just really nice
Send a message via AIM to bjimster1
Re: Inventor 9 Help
to change the length of the bumper, the best way i know is the following:
if the bumper is in the assembly (.iam)
  1. double click it /*so that you are into the edit part mode; everything else is transparent*/
  2. double click "Base 1"
  3. then click "Extend or Contract Body"
  4. click on the face at either end of the bumper
  5. click the yellow and red -> <- button
  6. specify the distance by which you want it shortened. **it automatically shortens it by the closest amount that will keep the space between the end face and the center of the hole the same. ** /*this is what is happening as far as i can tell*/
  7. click ok. /*now your done*/
if you are editing the part in its own file (.ipt) then skip step one.
i hope this helps.
-2006 UCF Quarterfinalists w/ 1345 & 21
-2005 Peachtree Quarterfinalists w/ 1180 & 462
-2005 UCF Quarterfinalists w/ 1694 & 348
CMU '11
Unread 21-01-2006, 12:06
VEN's Avatar
VEN VEN is offline
AKA: Volodymyr
Re: Inventor 9 Help
Hey, thanks, what I did is I used the extrude function and the cut button in it
