Go to Post "Dress to impress," typically, means no denim (sorry, Dean)... - Madison [more]
Unread 21-01-2006, 09:35
RedOctober RedOctober is offline
FRC #0291
RedOctober will become famous soon enoughRedOctober will become famous soon enough
Camera Feedback in the Code
Hey guys, with the camera where is the feedback being send to for the code? Are there variables set up that handle the feedback or do we have to create some ourselves? I can't figure out where they are if there already are some. Thanks!
Unread 21-01-2006, 14:05
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
Re: Camera Feedback in the Code
Look in the default camera code, and there is a function Tracking_Info_Terminal() in terminal.c, which basically provides debugging output for the camera. From this routine, you can see what variables the camera sets.
For starters, you can do basic control by just checking the values of PAN_SERVO and TILT_SERVO. But, before doing a real control loop with these, you might want to check some of the other variables as well.
Out of the Box Camera Code russell Programming 9 21-10-2009 05:28
Combined Camera and PID/Encoder Code Terry Sherman Programming 1 14-03-2005 17:59
Trying to import Camera code into program without. Kingofl337 Programming 1 18-02-2005 00:43
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
CMUCam2 Camera Code - Are important parts commented out? Mr. Lim Programming 4 14-01-2005 12:11
