Go to Post TL;DR: The robot battery (and your car battery) aren't going to electrocute you unless you stab a positive and negative wire from them into your heart. In which case you have plenty of other problems besides. - Kevin Sevcik [more]
Unread 21-01-2006, 14:46
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: Combining ADC, Serial, and Camera_s codes
Originally Posted by kaszeta
This file mostly worked for us. We had to add in an include for encoder.h and the Port_B and Port_B_Delta variables.
Now, encoders 3 through 6 work fine (indeed, I can run all four of them, each generating 1600 pulses/sec, and it keeps up) in tandem with the gyro and camera. But if try to use encoder 1, I get the red-light-o-death as soon as something triggers it. And if I try to enable encoder 2, it doesn't build:
C:\FIRST 2006\FRC 21 Jan 2006\encoder.c:131:Error [1205] unknown member 'INT3IP' in '__tag_223'
C:\FIRST 2006\FRC 21 Jan 2006\encoder.c:131:Error [1131] type mismatch in assignment
I noticed this thread, but I've confirmed that my p18f8722.h (in c:\mcc18\h) file is the exact one from the installation CD, and there are no others on the system. Are there two versions of this .h floating around?
In any case, I've put the code online (with team-strategy specific stuff removed, but this version shows the problem) at this link. I can probably run with just encoders 3-6, but wanted to run speed control on 1 and 2.
Any ideas?
Thinking you only wanted support for encoders on int 3 and int 4, that's what I included in the user_routines_fast.c I attached to my posting above. Use the file attached to this posting. Also, the p18f8722.h file included with the compiler is messed up. Use the one that's attached to this posting.
-Kevin
Kevin Watson
http://kevin.org
