Go to Post I owe these forums a lot more than $15 for all of the help and friends they have given me. - Karibou [more]
Unread 20-01-2006, 23:56
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
Re: 3D Animation Q/A
Originally Posted by Corporat
you could try to export as an autoCAD file (or something else) and then from AutoCAD export as a 3ds file. Tell me if it works out.
I've found that AutoCAD's .3ds export doesn't work that well (Curves get pretty screwy), but that exporting as a .igs from AutoCAD and then importing THAT works quite nicely...odd but true
Unread 21-01-2006, 14:30
Damelvin's Avatar
Damelvin Damelvin is offline
Damelvin
AKA: J.D.
FRC #1147 (Herdinators)
Team Role: Animator
Damelvin is an unknown quantity at this point
Send a message via AIM to Damelvin Send a message via Yahoo to Damelvin
Well i finally got around to working on the trashcan again and when I made it using a tube, I can't figure out how to close the hole on the bottom of the tube any suggestions?
Hear about the cannibal that passed his brother in the forest.
Unread 21-01-2006, 14:47
Capt.ArD Capt.ArD is offline
Animator
FRC #0116 (Epsilon Delta)
Team Role: Animator
Capt.ArD will become famous soon enoughCapt.ArD will become famous soon enough
the easiest way to make a trashcan is to use a cylinder, delete the top, and adda shell modifier. shell just makes your 2-d objects have thickness.
if you have to do it with a tube, selcet the vetices on the inside edge of the end of your tube, like where the bottom will be, and scale them down until they are close enogh to weld into one vetex. that will give you issues, though. for the easiest solution, you should just go ahead and plug the bottom of the tube up with a cylinder.
Unread 21-01-2006, 15:51
rowe rowe is offline
Eric Rowe
FRC #1097 (Site 3 Engineering)
rowe has a spectacular aura aboutrowe has a spectacular aura about
Send a message via AIM to rowe Send a message via MSN to rowe Send a message via Yahoo to rowe
Actually, the best way to plug the bottom of the tube would be to make a vertical segment in the tube, then convert to an editable poly. Using the vertex select tool, drag the vertex's for the middle segment down to just above the bottom (the height should be equal to the thicknes of the tube). Then delete the bottom inside poly's. And then cap the holes.
Eric Rowe | Alumn
Team 1097 | Site 3 Engineering
2005 Silicon Valley Regional Finalists
2005 Silicon Valley Regional Sportsmanship Award
2005 Sacramento Regional Finalists
2005 Sacramento Regional Sportsmanship Award
2004 Silicon Valley Regional Sportsmanship Award
2004 Sacramento Regional Visualization Award
2004 Sacramento Regional Engineering Inspiration Award
Unread 21-01-2006, 17:11
Damelvin's Avatar
Damelvin
AKA: J.D.
Team Role: Animator
I did the shell modifier one and it worked perfectly and easily. A little tinkering with mesh smooth and it looks great.
Unread 21-01-2006, 19:48
Damelvin's Avatar
Damelvin
AKA: J.D.
Team Role: Animator
Trying to make a desk light and i just cant get it to look right any suggestions. Pic below:
Unread 21-01-2006, 20:04
BuddyB309's Avatar
BuddyB309 BuddyB309 is offline
I freaking love animating!!
AKA: Peter Casey
FRC #1625 (Winnovation)
Team Role: Animator
BuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond repute
Send a message via AIM to BuddyB309
Better base. make the base a tinny part of a hemisphered sphere. And make it white with an anisotropic specular.
A.K.A Llama
check out my latest animations Appliance Night Out, Infant Intolerable, Fishing Like a Loony Tune, VVV Roadside Assistance
Life? I have a life. It is sitting at my computer and Animating. AND DRAWING!!! WEEEEEEE!!!!
Unread 21-01-2006, 21:44
Damelvin's Avatar
Damelvin
AKA: J.D.
Team Role: Animator
Talking Re: 3D Animation Q/A
I got teh hemispere but how do i do the anisotropic specular?
Unread 21-01-2006, 23:17
BuddyB309's Avatar
AKA: Peter Casey
Team Role: Animator
In the Material options Under shader basic Parameters change the tab that says Blinn to anisotropic.
A.K.A Llama
Unread 21-01-2006, 23:20
Nuttyman54's Avatar
Mentor, Tactician
That's done with materials. If you're looking for a brushed metal look, try this tutorial
Unread 21-01-2006, 23:59
Damelvin's Avatar
Damelvin
AKA: J.D.
Team Role: Animator
I was trying to make the lamp look like this:
But the base didnt come out well and I am not very good and cutting objects. I mess with the base some more. Also in teh picture how would i make those rings that wrap around the metal part of the light?
Unread 22-01-2006, 00:05
BuddyB309's Avatar
AKA: Peter Casey
Team Role: Animator
That is with a bump material. go to paint and make a picture with a single black line running horizontally through the picture then apply the bump map to the stand. Make sure to tile the bitmap so it will show up as multiple rings.
If you have any questions about the bump material look it up in users reference.
A.K.A Llama
Unread 22-01-2006, 00:09
BuddyB309's Avatar
AKA: Peter Casey
Team Role: Animator
When I render through video post and add glow, my final video never shows the glowing particles even though I see it being added through the render window. Ive tried material ID and object ID it doesn't work. Any body got any other ways to make glowing fireworks?
A.K.A Llama
Unread 22-01-2006, 00:42
Damelvin's Avatar
Damelvin
AKA: J.D.
Team Role: Animator
Which is better editable poly or editable mesh? Whats the difference betweem the editables: poly mesh normals and patch? I always used editable poly to make models, but mabye i should try others.
Unread 22-01-2006, 03:01
Damelvin's Avatar
Damelvin
AKA: J.D.
Team Role: Animator
I felt like making and xbox 360 just to have it in the animation as an easter egg.
Just wondering since I am just bitmaping a box with pictures of the xbox 360, how would I smooth the edges with effecting the pictures much. Also if I take off teh xbox 360 logo i should be ok and not get any trouble with microsoft?
Pic:
Animation Question Velaes 3D Animation and Competition 15 02-02-2005 00:11
FANATIC - Offseason Animation Competition opnickc 3D Animation and Competition 15 10-06-2004 20:54
A solution for Animation Judging for 2005 TKatsAniMentor 3D Animation and Competition 26 04-04-2004 15:29
A joke they called Regional Animation Competitions Lev 3D Animation and Competition 50 18-03-2003 21:18
How to develop your animation idea and keep your sanity too! Robby O 3D Animation and Competition 0 25-01-2002 01:25
