Go to Post This is what happens when Engineers try to design a sport. - Jim Zondag [more]
Go Back   Chief Delphi > Technical > National Instruments LabVIEW and Data Acquisition > LabView and Data Acquisition
Unread 21-01-2006, 14:56
Heretic121 Heretic121 is offline
The Resident Gamer -
AKA: Pat or Harry... if you ask its a long story...
FRC #0078 (AIR Strike)
Team Role: Tactician
Heretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond repute
Send a message via AIM to Heretic121
Installation Error
ok im getting this error while trying to install the NI_VISA
"RTX Runtime 5.5 is not installed" or someting to that effect...
so i searched for rtx runtime 5.5 and found it and got the exe... when i tried to install it i got this error
"your system is using a HAL that is not supported by rtx5.5.
please view the rtx release notes on information concering HALs, and instructions to change the HAL on your system
Deteced HAL: ACPI 1.0 - APIC platform up
# of PC's : 1
Installation Aborting"
anyone else get this??? and what would i have to do to fix it??? uninstall that HAL??? i didnt see anything in the release notes....
2004 - Team 121 Human Player
2005 - Team 121 Student Captian
2006 - Team 38 Drive Team Coach / Mentor
2007 - 2009 - Team 121 Mentor / Strategery Master
2010 - 2013 - Team 78 Mentor / Strategy / Scouting Lead
2014 - Team 78 coach
Unread 21-01-2006, 16:13
Danny Diaz's Avatar
Danny Diaz Danny Diaz is offline
Smooth Operator
AKA: FrankenMentor
None #0418
Danny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond repute
Send a message via AIM to Danny Diaz
Re: Installation Error
Please disregard this message. RTX is a real-time extension made by a company called VenturCom (now called Ardent or something) that VISA supports. This is not something you want to be installing, nor do you need to be concerned about.
-Danny
Danny Diaz
Former Lead Technical Mentor, FRC 418
Unread 21-01-2006, 16:18
-Danny
So i do not need RTX in any shape or form???
then how do i install the device driver for the NI-VISA??? it stops after the driver selection screen when i select NI-VISA to install it gives the "please install RTX 5.5" on the following screen and wont let me continue...
* yes i already installed the program but am not sure if the NI-VISA got installed with it???
Unread 21-01-2006, 17:08
I am also getting this error
"Property Node in VISA Configure Serial Port (Instr).vi->CMUcam2.vi->CMUcam2 GUI.vi"
which i saw in the other thread which said make sure VISA was installed + i just re-charged the back up battery and it is now fully charged...
Unread 21-01-2006, 20:39
Danny Diaz's Avatar
Smooth Operator
AKA: FrankenMentor
None #0418
I am also getting this error ...
Yeah, NI-VISA still isn't installed. Are you installing from the Driver CD or are you installing from the NI-VISA download? No matter, DO NOT select to install RTX support in the Driver Selection screen. This should be off by default (meaning NOT INSTALLED), unless you happen to have something that looks like RTX in your system. In the installer, make sure you do not have "RTX Support" as an install item, make sure it has an "X" on the icon before its name. The same goes for LabVIEW Real-Time support, there is no reason why you would need to install support for either of these.
-Danny
Danny Diaz
Unread 21-01-2006, 23:26
ok thx im just going try to do a clean install of LabView tommorow...
Software Development System Installation Mike Betts Programming 26 25-07-2005 10:48
MPLink Error cloudago Programming 2 01-02-2005 23:00
PHP and Wiki Error Venkatesh Website Design/Showcase 2 24-07-2004 15:51
MPlab error ryan_f Programming 9 24-05-2004 07:30
EMERGENCY! EPROM FULL error?!? CHSguard72 Programming 2 05-03-2003 20:51
