Go to Post I learned about how FIRST really is about so much more than a robot competition, it is about team building and the individual. - Adel Hodiwala [more]
Unread 21-01-2006, 16:40
jskene jskene is offline
None #0612
jskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to behold
612's ball launcher - prototype
Early launch video.
We are spinning the spoked wheels with 2 CIM motors turning ~ 2700 rpm. Aerodynamic improvements in the design have now increased this to >5000 rpm.
We plan to slow it down a bit for the competition.
Chantilly Academy's ball launcher
Jerry Skene, mentor OOO OOO 2010 - Chairman's Award- DC OOOOOOOOOOOOOOOOOOOOOOOOOOO
Chantilly Academy, Team 612 - 2009 - Engineering Inspiration Award; Finalist - New Jersey
-----------------------------------2008 - Chairman's Award; Kleiner Perkins Award -Buckeye ---| ---Team Spirit Award - NASA/VCU
-----------------------------------2007 - Chairman's Award - NASA/VCU ---| ---Finalist; Kleiner Perkins Award - Chesapeake
-----------------------------------2006 - Chairman's Award - Chesapeake ---| --- Engineering Inspiration Award - NASA/VCU --
Unread 21-01-2006, 17:18
phrontist's Avatar
phrontist phrontist is offline
Proto-Engineer
AKA: Bjorn Westergard
FRC #1418 (Vae Victus)
phrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond repute
Send a message via AIM to phrontist
Re: 612's ball launcher - prototype
That's faster than is legal, right? Man, that's really nice, you'll be able to get it right up against the limit :-)
University of Kentucky - Radio Free Lexington
"I would rather have a really big success or a really spectacular crash and failure then live out the warm eventual death of mediocrity" - Dean Kamen
Unread 21-01-2006, 21:38
FRC #0701 (RoboVikes)
Pretty cool, looks quite smooth.
the limit is actually really low, we thought we were going really slow (I estimated 4m/s from observing) but it turned out to be close to 10 m/s...
a ball shot vertical at 12 m/s only goes about 20 ft high!
Team 701
Unread 22-01-2006, 08:19
1574aviad's Avatar
1574aviad 1574aviad is offline
Aviad T. Rom
AKA: Aviad Rom
FRC #1574 (MisCar)
1574aviad is on a distinguished road
Send a message via ICQ to 1574aviad Send a message via MSN to 1574aviad
Looks really cool. Although seems like you almost hit someone .
I heart FIRST
2005- Israeli regional champions
2006-Israeli regional- champion alliance, innovation in control award, entrepreneurship award, woody flowers award
Championship event-14th on Curie, backup #4 on elimination
1574 Rocks
i turned into a mentor
Unread 22-01-2006, 10:04
Faith's Avatar
Faith Faith is offline
AKA: Plooshiska
FRC #1100 (The T'Hawks)
Team Role: Scout
Faith will become famous soon enoughFaith will become famous soon enough
Looks pretty neat. How accurate is it?
Unread 23-01-2006, 07:29
None #0612
We think that the speed is just about right actually. We angled the shooter at 30 degrees, and it lobbed the ball 35', just like the specs said. We plan to measure the speed with a police radar gun.
Unread 04-02-2006, 10:16
Schneidie's Avatar
Schneidie Schneidie is offline
AKA: Marc Schneider
FRC #0177 (The Bobcats)
Schneidie will become famous soon enoughSchneidie will become famous soon enough
Originally Posted by jskene
Early launch video.
Have you built an aiming system yet?
Schneidie
Unread 05-02-2006, 10:57
None #0612
Yes, we have designed and built the aiming system, and should be testing it this week.
We have a rotating turret, to which the camera is attached. The camera is queried by the robot controller, and the turret is turned one way or the other to keep the camera aimed at the green light, irrespective to the orientation of the robot chassis.
For elevation control, we use a curved deflector that changes the direction of the ball from vertical to horizontal - or some angle in between. This is controlled by the threaded shaft in the KOP. A modified Globe motor (5 x normal speed by bypassing one layer of its planetary gear train) rotates the shaft to change the elevation. The degree of elevation is computed by reading the target Y axis info from the camera's vertical servo, which we retain, in combination with the measured target area, which gives us an approximation of the range to the target. We ditched the X servo, as the turret rotation serves this function now. We plan to empirically generate a lookup table to correlate the camera elevation and target size to the required elevation of the curved deflector.
We are hoping that this will give us automatic, on-the-fly targeting capability, with no operator interaction. Of course, theory and practice seldom have anything to do with each other.
We'll find out more this week, and will post videos if things work out.
Unread 05-02-2006, 11:22
Sachiel7's Avatar
Sachiel7 Sachiel7 is offline
<Yes I managed to flip it
AKA: Shayne Helms
FRC #1132 (RAPTAR Robotics)
Sachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really nice
Send a message via AIM to Sachiel7
Again (I've been saying this alot this year...) that sounds extremely familliar ^
-=Sachiel7=-
There's no such thing as being too simple!
Look for Team #1132, RAPTAR Robotics at the VCU Regional this year!
Ball Launcher Joe_Widen Kit & Additional Hardware 15 06-03-2006 02:59
Team 125 Ball Shooter Prototype! Brandon Holley Technical Discussion 21 21-01-2006 00:07
pic: team 125 minature ball shooter prototype Brandon Holley Extra Discussion 5 14-01-2006 00:52
Second FIRST Ball Launcher generalbrando Technical Discussion 14 13-01-2006 09:08
First FIRST ball launcher? Rick TYler Technical Discussion 13 10-01-2006 22:42
