Go to Post Besides, all the FIRSTers that I know - are children at heart. - JaneYoung [more]
Unread 21-01-2006, 16:41
Windward's Avatar
Windward Windward is offline
FRC #1452
Windward is an unknown quantity at this point
default camera code edit
Does the default code for the camera (MPLab) have some sort of setting or special function that prevents programmers from adding their own code? The camera code runs perfectly (as far as we can tell anyway), but our code that we added to the file under Default_Routine (which worked on other default codes) doesn't work now. Is there something we are supposed to change or do?
Unread 21-01-2006, 17:02
scitobor 617's Avatar
scitobor 617 scitobor 617 is offline
More nerd than you can handle!
AKA: Alan Meekins
FRC #0617 (HSHS 617 "DUKE")
scitobor 617 will become famous soon enoughscitobor 617 will become famous soon enough
Send a message via AIM to scitobor 617
Re: default camera code edit
Make sure that you call the Default_Routine from the Process_Data_From_Master_uP function, it is commented out in the default camera code.
Beta testers needed!
http://www.nullagent.no-ip.com
Your kidding, there are other operating systems besides Linux?!
Unread 21-01-2006, 17:15
Windward's Avatar
FRC #1452
Mine isn't commented out.
Unread 21-01-2006, 17:41
Kevin Watson's Avatar
La Caņada High School
FRC #2429
As pointed out above, the *call* to default_routine() from Process_Data_From_Master_uP() is probably still commented out. This is done for safety reasons. Also make sure that code in default_routine() doesn't modify the camera's pan and tilt PWM values.
-Kevin
Kevin Watson
http://kevin.org
Unread 21-01-2006, 18:11
Windward's Avatar
FRC #1452
-Kevin
As I said, I checked in main.c and it is not commented out, unless it is called another time which I didn't check.
Unread 21-01-2006, 19:17
AKA: Alan Meekins
It, default_routine(), should be called from user_routines.c by the function Process_Data_From_Master_uP(). Another way to make modifications is to just edit Process_Data_From_Master_uP().
Unread 21-01-2006, 20:31
Jared Russell's Avatar
Taking a year (mostly) off
Also make sure you aren't calling any other functions that modify PWM values after Default_Routines().
Unread 25-01-2006, 18:11
Windward's Avatar
FRC #1452
My bad. Turns out it was commented out somewhere else (or I went without sleep to long).
When I uncommented Default_Routine(), the camera started acting strange. The pwms would switch numbers back and forth such that the camera was vibrating.
I checked the code to see if it changed the pwms for the camera, and didn't find anything.
Unread 25-01-2006, 18:33
Andrew Blair's Avatar
FRC #0306 (CRT)
Trouble is, in that Default_routine function you uncommented, there are other things that control pwm01 and pwm02. So you, at the top of default_routine, just delete those two lines of code that modify pwm01 and pwm02.
-Sir Francis Bacon
-Albert Einstein
Out of the Box Camera Code russell Programming 9 21-10-2009 05:28
problems using gyro/adc code with camera default code tanstaafl Programming 7 22-01-2006 23:09
Getting the Camera and Default Code to Work nukem Programming 5 18-01-2006 11:48
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
