Go to Post I don't know how you can blame a robot getting stuck in the goal on the GDC. The field drawings showed all of the dimensions of the goals. If a team doesn't want to risk getting stuck then they need to plan around it. - JamesBrown [more]
Unread 21-01-2006, 12:54
AMIRAM AMIRAM is offline
AMIRAM is an unknown quantity at this point
using all port pins
Hi
can anyone tall me how can I export/inport data from all of port a pins
in the defult code the pins can be use only as bits
thanks
Unread 21-01-2006, 15:46
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
Re: using all port pins
You may wish to restate your question, I'm having trouble understanding it. If you're trying to grab all of the data off of PORTA (the register in the microcontroller), then look at the header files (ifi_picdefs.h) and find an 8-bit variable with the name PORTA somewhere in it (don't remember exactly what it's called).
Shift to the left, shift to the right!
Pop up, push down, byte, byte, byte!
Unread 22-01-2006, 01:58
In the FRC u have 18 digtal inputs/outputs that u can use i want to use 8 of them together to connect another microcontroller ...
can u understand now ?
Unread 22-01-2006, 14:37
You might be better off using the TTL serial port. If that's not an option, many PICs have a parallel port - I don't know if the pins that it uses are wired out to the front of the RC, but if they are you could use that to shift entire bytes in and out.
Failing that you can always just use the digital ins, shift and add. Something along the lines of IN_1 << 7 + IN_2 << 6 + IN_3 << 5 etc.
Unread 23-01-2006, 00:52
duane's Avatar
duane duane is offline
FRC #0701 (RoboVikes)
duane is an unknown quantity at this point
Send a message via AIM to duane
You can look at the processor specific header file to figure out which port you want to use (I'm not sure which one it is this year). But here's an educated guess.
In ifi_aliases.h rc_dig_in01 is defined as:
#define rc_dig_in01 PORTBbits.RB2
The definition fo PORTBBits comes from the processor specific include file. There is also a corresponding definition for PORTB which is an unsigned char. (The linker must have a memory map that defines what addresses these ports are located.) That should provide you with an 8-bit wide read of all the lines.
CMUcam2 Serial Port Diagnostics Kevin Watson Programming 13 18-02-2006 15:05
TTL port to a serial port on a demo board ImmortalAres Programming 16 09-07-2005 23:44
Updated: Serial Port Driver Code Kevin Watson Programming 4 05-02-2005 18:39
New Serial Port Driver Kevin Watson Programming 16 09-01-2005 01:56
[ECDU]: CHAT-7/19 Corey Balint FIRST-related Organizations 5 19-07-2004 23:44
