Go to Post 254 bends CIM shafts every now and then in the drivetrain. I didn't believe it was possible until I saw it myself. - AustinSchuh [more]
Unread 22-01-2006, 03:16
AKA: Brad
#0190 ( Gompei and the Herd)
Re: easyC trouble
Originally Posted by Erics626
Perhaps I should be more specific. We are trying to write a program for count wheel rotations. We want the left wheel to travel a different number of rotations than the right wheel. I created two different user functions, one for counting the left wheel and one for counting the right wheel. We implemented these functions into autonomous, but the wheels do not start at the same time. Instead, the left wheel goes the distance we set, and as soon as the left wheel is done, the right wheel begins to rotate and start its count.
I'm not sure exactly what you are really trying to do - sounds like making a turn using the wheel encoders. But to do literally what you asked for, you need to start both wheels going. Then in a loop, read each wheel count, and using two IF statements, stop each wheel when its count is greater than or equal to the count your are looking for.
That way the wheels will both be running at the same time and they will each stop independently after the correct number of rotations.
Brad Miller
Robotics Resource Center
EasyC v2.0 is mandatory for FVC! skimoose FIRST Tech Challenge 7 14-01-2006 18:37
Kickoff easyC workshop integrated into EasyC help file Dan Larochelle Programming 0 11-01-2006 06:12
EasyC v. 2.0 - New features, custom user functions, and more! artdutra04 FIRST Tech Challenge 1 02-11-2005 13:36
