Re: The Chester Challenge 2006
Impossible? Explain..... what rules say you cant shoot from the start position? This is far more possible than scoring the viso n tetra on the center goal in 15 seconds..... |
OK - much as I hate to give in to nay-sayers- I'll alter the challenge- the first Allliance that scores 90 ball-points (sans bonus) in the autonomous mode from ANYWHERE on the field and in an official FIRST seeding or elimination round will win the TIKI. So--I made it easy for you- can you do that? I think its too easy but ..... WC ![]() |
I looked up the field drawings and did a quick check
the center starting position box is 27' along the long side of the field to the end, and 13' from the center. Knocking off a few feet to the middle of the box, its 11'. (27^2 + 11^2) ^ 0.5 = 29 feet to the bottom of the goal at floor height. The example FIRST gave for the 12M/S ball speed limit says the ball will travel 35 feet if fired at max speed with a 30° angle. Thats 35 feet to where it hits the floor. So its looking like you would have to exceed the muzzle velocity limit to swish balls through the goal from the center starting postion, or the one further away. One other factor: the way the bots are all lined up along one side, will the two farthest bots be able to shoot towards the center goal without hitting the next bot in the back of the head? |
#7
i think the hardest part of this challenge will be that the balls would have to be timed so that they do not hit each other in mid air wich would cause them to bounce off each other and not go in.
#8
that means each ball is flying at 1/2 S intervals, which will put them 6 meters apart thats a lot of space between the balls in flight: 10" balls with 226" of empty space between them the odds of two balls hitting in flight is 10/226 = about 5 out of 100. The odds are 20:1 in your favor (no collisions in midair) |
#9
ya this has nothing to do with the subject but I need help trying to post or what ever it is that you have to do to put a question on the website... thanks
#10
So, you have ten, 3 balls instances of clearing. At two seconds apart. So, to clear all the balls, it would be 10*2 =20 seconds to clear all the balls completely. So, by the end of the ten seconds, there would be ten seconds of balls to clear, backed up. (10/2)*3 balls~15 balls left So at the end of the period (through my rough estimation), there are fifteen balls to clear, or, towards the end of the autonomous period, there are 10 or 12 to get in the way. I wonder if 10 or 12 balls, some still jangling around, could present enough of an obstacle to prevent some incoming balls from coming in? And what about the feeder chute? I wonder if that'll jam? I think, on top of needing a killer alliance to do it, this challenge is going to be harder than the intro suggests... |
#11
two weeks over- and the TIKI is still safe at home
Thirty balls scored in autonomous? Three robots each getting all three balls in the center goal? A 100 point autonomous round... Could the challenge AGAIN be beyond the abilities of the ENTIRE FIRST community? True- the new alliance picking rules seem to inhibit alliances of three hot shooters. But how many bots are scoring 10 balls in autonomous anyway? I predict that IF this challenge can be met it wont happen until the elimination rounds at the Nationals. Until then the TIKI continues to gather dust..... WC ![]() Last edited by Wayne C. : 12-03-2006 at 21:53. |
#12
I don't think this challenge is as practical as you think it is.
Some teams don't even have the capability of shooting, and most that do are not that accurate or are going purly on dead reconing as to where the goal is. The chance of getting 3 teams on an alliance that can even shoot in 10 balls in autonomous are slim. Those robots that use the camera to target take a while to find the light, especially if the camera is hooked up to a slow moving turret. The time it would take to Drive close to the target, track it, and fire ten balls off is far greater than 10 seconds. The opposing team normally has at least one robot that is programed to simply drive forwards, the idea being that the robot would interfere with an opposing robot and prevent them from scoring. This would throw off almost all dead-reconing shooters and most tracking shooters (at least it would prevent one ball from going in). This challenge is no small task. It would take, in my opinion, a miracle to accomplish. The chances of it being done are far below 0%. |
#13
After having attended one regional, my previous views on this challenge have changed drastically. Seeing the lack of shooters(including ourselves), and the low autonomous capability of even the better shooters, I think this challenge is nearly impossible. Simply the fact that balls bounce out lower the chances to nearly zero, let alone getting an alliance with that kind of firepower. My thoughts: the Tiki with accumulate another years worth of dust. Perhaps the challenge would be nearly possible if changed to "twenty balls in the center goal during autonomous" or "All thirty balls scored during autonomous, anywhere".
#14
#15
So- did anybody do it?
The closest we came was in one round of IRI (that was rerun!) where the three partners got in 27/30 balls. Anybody get all 30? WC ![]() |
| 2006 Pennsylvania Robot Challenge (PARC) | team222badbrad | Off-Season Events | 91 | 17-05-2006 15:45 |
| DARPA Grand Challenge 2006 | mechanicalbrain | Chit-Chat | 4 | 12-01-2006 23:00 |
| pic: A New Challenge in 2006 | Noah Melamed | Extra Discussion | 2 | 12-01-2006 12:29 |
| [Official 2006 Game Design] OK, so YOU design the 2006 game... | dlavery | FRC Game Design | 29 | 08-01-2006 00:21 |
