Go to Post This, right here, is why I participate in FRC. Changing lives, one corndog at a time. - Jared Russell [more]
Unread 19-01-2006, 19:51
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
Re: CmuCam problem
try drawing your power from the digital out instead of the PWM out that fixed the problem for us with the camera not tracking
KK4KQO
http://voltair.us
Unread 20-01-2006, 03:26
Joe Hershberger Joe Hershberger is offline
National Instruments
AKA: jhersh
FRC #2468 (Appreciate)
Joe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to all
Re: CmuCam problem
That's odd. The PWM out should supply 7.2V needed from the backup battery (which must be hooked up), where as the digital port should be only 5V, and not sufficient to overcome the drop in the voltage regulator on the camera. Also, the servos, if plugged into the camera, should require the 7.2V to operate as well. If they are plugged into the RC, then it should still be needed.
But I guess if it works...
-Joe
Unread 20-01-2006, 11:17
mallot1243's Avatar
mallot1243 mallot1243 is offline
FRC #1243
mallot1243 is an unknown quantity at this point
Re: CmuCam problem
My bad, Windows 2000 Service Pack 1, I had to go buy Win XP yesterday.
Unread 22-01-2006, 10:25
Zoom's Avatar
Zoom Zoom is offline
Lost User
AKA: Umair Nasir
FRC #0369 (Nuts & Volts)
Zoom is an unknown quantity at this point
Send a message via MSN to Zoom
Re: CmuCam problem
Thanks for the help. we got the cam working. there was a problem with the backup battery. it would power the camera but the servos wouldnt move. after changing the battery it started to look for the target. As in other post the camera moved away from the target. switching the jumper fixed that. it works perfect. if you are haveing any problems try to change the battery. also change the jumper. so it doesnt run away from the target.
A Program isnt finished until the Programmer dies...
Unread 22-01-2006, 11:14
Re: CmuCam problem
That's good news.
I've been away from CD for a few days visiting rookie teams, so I'm sorry about not responding with more ideas Zoom.
Unread 22-01-2006, 11:20
Faith's Avatar
Faith Faith is offline
AKA: Plooshiska
FRC #1100 (The T'Hawks)
Team Role: Scout
Faith will become famous soon enoughFaith will become famous soon enough
Re: CmuCam problem
What if our problem consists of putting a (I think) transformer in incorrectly and blocking it off from the air, accidentally melting it?
This did actually happen, but the camera still works (not quite as well) and we're getting some new parts.
Unread 22-01-2006, 12:49
BrittanyV BrittanyV is offline
FRC #1025 (Impi Robotics)
BrittanyV is on a distinguished road
Re: CmuCam problem
Hey-
Out team is having a horrible time with the camera- much like what everyone else is having in this thread. The only difference is sometimes the camera will search and sometimes it won't. We had the camera working at one point, but now it doesn't. We started from square one, but it still won't work. We're using the camera_s code, and we have calibrated the camera just as the instructions say. We noticed that the red light goes on when the camera sees the target in LabVIEW, but when we try to search with Kevin's code, it seems to be seeing the target all over.
If anyone can offer any help at all it would be much appreciated!
Unread 22-01-2006, 15:13
The yellowdart's Avatar
The yellowdart The yellowdart is offline
FRC #1506 (Metal Muscle)
The yellowdart has a little shameless behaviour in the past
Re: CmuCam problem
pwm 1 and 2 are right on the camera board...on the top or bottom.....depending on the mounting of your camera
Unread 22-01-2006, 15:21
Safarley2901's Avatar
Safarley2901 Safarley2901 is offline
AKA: Steve Farley
FRC #0808 (Mechanical Mayhem)
Safarley2901 has a spectacular aura aboutSafarley2901 has a spectacular aura aboutSafarley2901 has a spectacular aura about
Re: CmuCam problem
Did you try changing the focus of your camera, ours works fine. But If its focussed wrong it wont track it at all.
2005 Pittsburg Regional Finalists
2005 Cleveland Regional Semi finalists
Labview CMUcam demo problem Windward LabView and Data Acquisition 19 11-08-2007 02:33
CMUcam setup Ryan Collings Programming 26 13-01-2006 01:00
Need a realistic Statics Problem sanddrag Technical Discussion 10 05-12-2005 15:07
The problem with scouting... archiver 2001 10 23-06-2002 23:49
Major problem with chipphua motors aka Scott White Motors 18 19-03-2002 19:44
