You send me into orbit.
Unread 22-01-2006, 12:00
AMIRAM AMIRAM is offline
AMIRAM is an unknown quantity at this point
Re: USB-Serial Cable + Terminal
Originally Posted by Spencer E.
Is anyone having trouble with using a USB-Serial cable to recieve information in the Terminal window? I don't know if it's the software or the cable but whenever I load a program onto the FRC RC, I get nothing back . If anyone has any idea what the problem is or what to do, it would be greatly appreciate for your help.
Hi
i tried to connect it ones to another app and it didnt work becuse the usb is 5v and the computer serial is -+12v in our RC we have dc-dc converter....
also u should check the usb-serial driver is win-xp compatible
Amiram
Using USB with Serial Tower Mick Lego Mindstorm Discussion 11 07-11-2006 09:54
CMUcam2 Serial Port Diagnostics Kevin Watson Programming 13 18-02-2006 15:05
Updated: Serial Port Driver Code Kevin Watson Programming 4 05-02-2005 18:39
New Serial Port Driver Kevin Watson Programming 16 09-01-2005 01:56
USB to Serial -- Working Device Found! Eko Programming 10 23-02-2004 12:56
