Go to Post Don't fix mechanical problems with software, ever. - Chris is me [more]
Unread 22-01-2006, 12:47
esquared's Avatar
esquared esquared is offline
Keeps saying 3-2-1-Rush...
AKA: Angry Eric
no team (Volunteer!)
Team Role: Mascot
esquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond repute
Re: Camera never finds target, stays at "Searching..."
Originally Posted by Mike
Ahh, I'll try that first thing when I get bot access. I thought we had to use the LabVIEW program to get the values for the code.
So what's the point of the LabVIEW program?
Mike,
Our team used LabVIEW to come up with the correct calibration values just like you did. Similarly, when we went to use the bells and whistles code on the robot (the EduRC actually) it seemed to lose track of what we had told it. The key is that the camera code by default puts the camera BACK into RGB even if you did your calibration values. This isn't a simple switch in camera.h, turns out it's actually a bit in the COMA register (the bit ID escapes me at the moment but it is documented).
Once we figured that out, we had our EduRC bot with the bells and whistles code following our GLOD* with no more issues, based on the 'highly calibrated' Labview values.
-Eric
*GLOD=Green Light Of Doom
How To Use the Google Camera generalbrando Kit & Additional Hardware 2 07-02-2006 16:00
Camera pointing error? Craig Putnam Programming 14 21-01-2006 02:52
For anyone who doesn't get the camera code..... Jake M Programming 8 16-01-2006 18:56
LabVIEW - CMUcam finds target but cant track bear24rw Programming 6 13-01-2006 21:43
CMUCam2 Camera Code - Are important parts commented out? Mr. Lim Programming 4 14-01-2005 12:11
