Go to Post So remember, no matter what the odds, your wildest dreams can come true with science and technology. - Ian Curtis [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 22-01-2006, 13:05
in between teams
AKA: Luke Van Oort
Re: Beware - transmission output shaft is not 5/8"!
Originally Posted by blue_crew
how easy would it be to extend the drive shaft output? our team is planning on using a six wheel drive but without using the skyway wheels. rather some modified off the shelf wheels. the problem is they are 2 inches wide at the widest point (the tread is only 1 inch) and the easiest way to line them up is to extend the output. any help?
Try moving your wheels a bit on the axle shaft to see if you can get a clear chain path. See if moving the center wheels out a bit and bringing in the others helps, or something similar.
Team 1219: 2009 - Mentor
diameter of transmission output shaft sj31419 Electrical 5 17-02-2005 22:09
supplier for 5/8" shaft david.clark Kit & Additional Hardware 2 17-01-2004 18:13
Cutting the output shaft Kevin A Technical Discussion 2 18-02-2003 01:47
Securing hex shaft to drill output D. Gregory Technical Discussion 6 24-01-2003 14:05
