Go to Post there is no such thing as too many parts or useless parts, only parts you dont need yet. - Cuog [more]
Unread 22-01-2006, 13:06
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
Re: CMU Camera kills robot controller if not found.
How will this help us if the camera is missing, broken? Then on power up, it locks up the code, because the robot controller can't find it?
Maybe I didn't explain the problem good enough above. The camera works great when it's connected and the robot controller finds the camera on power up.
But if the camera code is still in the controller and you disconnect the camera from the controller, it acts like it searchs for the camera, never finds it, excutes one cycle enough to do one printF statement, then locks up.
If the robot controller finds the camera on power up, then the camera dies while the controller is powered up, it's not a problem. The robot controller doesn't care, it just doesn't get any packet information.
Originally Posted by Kingofl337
Run the camera off a analogue port for power. The camera will be powered from
the 12v battery instead of the backup.
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Persistent "no robot controller found" error 1594code Programming 12 20-02-2006 20:59
CMU Cam not Tracking Properly on Robot coastertux Programming 6 29-01-2006 00:02
Camera not found! SpeakerSilenced Programming 0 21-02-2005 12:54
Camera not found!!! Code\\Pilot Programming 11 02-02-2005 00:04
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
