Go to Post ... so I have to ask: ... Are you nuts? - I hope you are - as crazy as Dean :^) - KenWittlief [more]
Unread 22-01-2006, 10:44
cladkins cladkins is offline
FRC #1262
cladkins is an unknown quantity at this point
Exclamation Pan Turning To the left
I know this has probably been posted already, but I just couldn't find it. But when the Pan servo is connected to the camera. In demo mode it turns to the left and sticks their until you go in the java file and set the servo to 0 and it go to the center but will not go to the right. Please Help!!!
Unread 22-01-2006, 15:10
The yellowdart's Avatar
The yellowdart The yellowdart is offline
FRC #1506 (Metal Muscle)
The yellowdart has a little shameless behaviour in the past
Re: Pan Turning To the left
Alright.....here is what is going on....you do not have your servos properly calibrated.....use the software to put your servos at the neutral/middle state which is 127, take the screws out that hold the plastic rotating servo plates and move your arm to the position you want it. If that doesnt make sense or help...let me know.... Johnbk14@gmail.com
When you put it all together, and turn on the power it goes to where the neutral state or middle state should be.....
Hope that Hlelps
- Team 1506 programmer John K.
Turning Left and right reilly Motors 2 18-02-2005 11:35
Autonomous Camera Integration GregC Programming 2 06-02-2005 14:34
Canadian fined for turning left while on his Segway MrToast Dean Kamen's Inventions 2 21-10-2004 17:34
Using an FRC with the RCX? Astronouth7303 Programming 21 15-04-2004 14:14
Speed limiting code from last year in C? Josh Siegel Programming 6 01-04-2004 22:27
