Go to Post 'We're back to square one! and while we're at it, let's redesign square one.' - Bethie42 [more]
Unread 22-01-2006, 16:51
Andrew Blair's Avatar
FRC #0306 (CRT)
Finding the *final* Servo Center values?
I'm using MPlab to play around with writing some fire control code, with the bells and whistles version of the default code. Trouble, I can't seem to find the point in the code where the servo center values are assigned with a value from eeprom or the default settings. I need to write a function that returns the value of center, that the controller has decided to use.
-Sir Francis Bacon
-Albert Einstein
Unread 22-01-2006, 17:43
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: Finding the *final* Servo Center values?
If the software decides to use default values from tracking.h, this is done at the end of tracking.c. If it uses EEPROM, the values are part of a memory block move and not explicitely initialized. See Get_Tracking_Configuration(). Anyway, the values you need are in Tracking_Config_Data.Pan_Center_PWM and Tracking_Config_Data.Tilt_Center_PWM.
-Kevin
Kevin Watson
http://kevin.org
Unread 22-01-2006, 18:02
FRC #0306 (CRT)
Thanks!
-Sir Francis Bacon
-Albert Einstein
Servo behavior question / advanced servo/PIC programming question DanL Electrical 12 18-10-2005 18:33
Servo Compact Design Problems!!! Dominator_Legen Electrical 22 07-04-2005 18:15
Servo Help Dominator_Legen Motors 3 11-03-2005 19:50
Full list of teams & competitions archiver 2001 14 24-06-2002 00:52
KSC Results archiver 2000 2 23-06-2002 22:19
