Go to Post I think rovers on Mars are way cool but you won't get a crowd of enthusiastic participants cheering as they trudge 150 meters a day. - Andrew Schuetze [more]
Unread 22-01-2006, 19:25
sjung9442 sjung9442 is offline
Student Mentor
FRC #0122 (NASA Knights)
sjung9442 is an unknown quantity at this point
What is the first step for programming?
Our programmers are all first year students. And our programming mentor is "Out of country" so, we can't do anyting right now.
What is the first step for programming? We have to do someting before our mentor gets back from the trip, but we are not sure.
Which part of program do we have to look at? And where should we start?
We played with camera little bit, but that is all we did so far.
Unread 22-01-2006, 19:33
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Re: What is the first step for programming?
Whoa it's tough if you don't have any programmers there to help. Is your robot built enough to drive yet?
I would strongly suggest using EasyC to build your code. In the Help section are tutorials. Walk yourselves through those and see how your robot behaves. Most importantly, if you are testing your code on the robot, make sure you have it up on blocks so that the drive wheels aren't in contact with anything. A 100 pound out of control robot can be dangerous! Take small steps and see how your robot reacts to each change. Trying to get it all programmed at once won't work. If your bot isn't ready to go yet, just run through the tutorials to at least get yourself acquainted with EasyC, skipping the parts that instruct you to compile and download.
Unread 22-01-2006, 19:49
pwilczynski's Avatar
pwilczynski pwilczynski is offline
FRC #0236 (Techno Ticks)
Rookie Year: 1993
pwilczynski is on a distinguished road
If you have the resources, you might want to try and set up a motor board with maybe three motors, speed controllers, robot controller, battery, backup battery, sensors and maybe a servo. By using this instead of a robot you will be able to test all of your code before the robot is built and move very slowly through the process without havingyour build team hanging over your backs and trying to build stuff.
As for software, I would also go with EasyC, at least for the start. If you want to dive into the more complicated stuff, the default code is already programmed for two joystick control and certain other buttons doing other things. If you have any questions or comments, just post them. I'm sure you will get plenty of support.
Unread 22-01-2006, 20:25
scitobor 617's Avatar
scitobor 617 scitobor 617 is offline
More nerd than you can handle!
AKA: Alan Meekins
FRC #0617 (HSHS 617 "DUKE")
scitobor 617 will become famous soon enoughscitobor 617 will become famous soon enough
Send a message via AIM to scitobor 617
As a pre-EasyC and mentorless programmer I would advise you to try jumping into C and the default code first. I would suggest reading a C tutorial(heres a good one ) then read the 2004 programming reference guide. If you have never programmed before this may be a difficult course but I believe it will provide you with greater understanding. Whatever development route you take, I would suggest trying to setup a test board, as previously stated, and/or try reprogramming an old robot(if you have any).
Beta testers needed!
http://www.nullagent.no-ip.com
Your kidding, there are other operating systems besides Linux?!
Unread 22-01-2006, 20:47
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
One way to start is to think about what your robot does and figure out what the various outputs (motors, servos, pneumatics, etc.) and inputs you have. From there, build a list of things which you want to do code-wise, and put it in order of priority. For instance, our team this year might have a list which looks something like:
  1. Drive
  2. Automatically track goal using turret
  3. Auto-range finding
  4. Autonomous
After you have a list which includes the major things you plan on doing, break the highest priority one down into smaller, easier to manage parts and implement those in order. Going off of my example, here's what you might have for "Drive:"
  1. Simple 1-to-1 joystick-to-drive train mapping
  2. Encoder tracking
  3. PID controller
Once you get basic driving working, you can begin to move on to something which may be less critical, but still important. If you have multiple people, you can multitask, by having one person work on one subsystem, someone else on another, etc.
Basically, the easiest way to approach writing code for your robot (or any computer), is to break it down into easily manageable pieces which you stick together to make your more complex system.
Unread 22-01-2006, 21:23
These taught me the default code back in 2004, and I see no reason why they shouldn't do the same for you.
http://team195.com/documents/FIRST_C..._Presentation/
(Look through them in order. Don't just skim them. Hit the play button (F5) and listen to the voice over. It really helps to hear it and see it.)
Unread 22-01-2006, 21:54
Student Mentor
Thank you all of you for what you have done.
I guess we have to work on drive control first. Motors and speed controllers.
I will look on Easy C little bit more. I liked the program but did not know how to use it. If there is a tutorial, I will try to use that to learn how to use that program. We may be first year programmers in FIRST Robtics, we are good programmers, so I think we will be fine. We just needed some first step guide. Thank you again to you all.
A new step in collaboration: FIRST Programmers' Guild Tom Bottiglieri Programming 48 15-02-2006 14:46
Taking the animation problems a step further... Penguin 3D Animation and Competition 7 10-03-2005 15:10
JVN step aside... TAS is now officially famous! Aidan F. Browne General Forum 13 22-08-2004 11:54
Going over 6 inch step with 12 inch wheels Joe P Technical Discussion 25 12-04-2004 11:15
