Re: pic: 888 Ball Shooter Prototype
We thought the wheel size would take awhile to speed up. (Based on preliminary tests with softball pitching machine), but the large CIM gets to speed fairly quickly.
We took off the belt tension thing and mounted the CIM flat against the plywood. -Chris |
How did you mount it?
Did you drill and tap more holes? Did you just use the mount that the tensioner lever was attached to? |
We removed the pulley and used the existing stud, as well as drilling and tapping a hole in the corner that sticks out of the face.
| Team 358 Shooter Prototype | Xero0ne | Robot Showcase | 14 | 20-01-2006 21:03 |
| pic: cvt prototype | CD47-Bot | Robot Showcase | 5 | 29-01-2004 01:10 |
| pic: Swerve^2 Prototype | CD47-Bot | Robot Showcase | 24 | 23-01-2004 12:11 |
| pic: Team 857 Prototype Killough 2002 | CD47-Bot | Extra Discussion | 19 | 13-10-2003 08:12 |
| pic: Team 888 14" | CD47-Bot | Extra Discussion | 2 | 16-03-2003 17:44 |
