Go to Post Don't let what you think you can do get in the way of what you can do. - Daniel_LaFleur [more]
Unread 22-01-2006, 22:00
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Re: problems using gyro/adc code with camera default code
Try going to Project > Set Language Tool Locations > Microchip C18 Toolsuite > Default Search Paths & Directories > Include Search Path What this is providing is the location for it to search for all the compiler includes (the ones in between <>)
Mine is by default nothing, but your system may be set up differently. I'm guessing here, but I would try setting C:\mcc18\h as the location.
Good luck,
Mike
http://www.mikesorrenti.com/
Unread 22-01-2006, 23:09
tanstaafl tanstaafl is offline
AKA: Matt Kovacs
FRC #0931 (Perpetual Chaos)
tanstaafl is an unknown quantity at this point
Send a message via MSN to tanstaafl
sorry, but I haven't been able to post for a bit. it turns out that my prob was that I had a typo. the mentor that's helping me out noticed that after we were going over the code. it wasn't a mispelled word, I just had a 3 in a variable name when there was supposed to be a 1. however, I did still need that p18f8722.h file, so thanks for that, kevin. next time I have a prob, I'll make sure I don't have any typos before I post.
A competent and self-confident person is incapable of jealousy in anything. Jealousy is invariably a symptom of neurotic insecurity
interrupt in default code Gal Longin Programming 5 04-02-2006 20:10
If you could write the default code... Kevin Watson Programming 18 04-08-2005 10:41
Combined Camera and PID/Encoder Code Terry Sherman Programming 1 14-03-2005 17:59
Best Way To Insert Autonomous Code Into Default then load help.? :-)? gemccnp Programming 2 05-02-2005 18:58
CMUCam2 Camera Code - Are important parts commented out? Mr. Lim Programming 4 14-01-2005 12:11
