Go to Post I must caution against using my sense of humor as any sort of litmus test for good taste. - dlavery [more]
Unread 22-01-2006, 08:11
AMIRAM AMIRAM is offline
AMIRAM is an unknown quantity at this point
Gyro code problem
Hi
im tring to use the gyro code . the gyro is working fine but
the p1_x is not getting changing when i move the joystick...
(p1_x moves when i move the y - axis)
can anyone tall me what do i need to change in the code to make it work?
thanks
Unread 22-01-2006, 12:55
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: Gyro code problem
Originally Posted by AMIRAM
Hi
thanks
If you're using my code, it's very likely that the default code is still commented out in user_routines.c/Process_Data_From_Master_uP(). This is done for safety reasons.
-Kevin
Kevin Watson
http://kevin.org
Unread 22-01-2006, 13:30
Im calling the Default_routine function from ther and it still not working...
i think the problem is in the serial port routine becuse when im traing to use "FRC SERIAL PORT" code its not working as well
Amiram
Unread 22-01-2006, 15:49
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
Hey Amiram,
מה קורה?
אני ממליץ שתשתמש בבודק שגיאות האיות באנגלית, ככה יהיה להם יותר נוח לקרוא את ההודעות שלך ולעזור לך...
-ליאב
קבוצה מס' 1578
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
Unread 22-01-2006, 21:36
Back after 4 years off
FRC #5279
-Kevin
I was wondering if you could elaborate on this, I did not comment much of what you had commented whaen I added your gyro code to my code from last year, what risks does this present?
James
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 22-01-2006, 22:05
devicenull devicenull is offline
Robot? We need a robot?
Rookie Year: 1234
devicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nice
James
Uncalibrated joysticks + robot motors. Not a good combination. I think it's better off disabled by default.. less chance of you not realizing it's got enabled drive motors.
AMIRAM, It sounds like you either have a bad joystick, or someone was playing with the Disable switches on the OI. I suggest trying another joystick, or looking at those switches.
Unread 22-01-2006, 22:14
FRC #5279
I dont see how this being uncommented is any different then the default code, I changed Kevins variable i in order to avoid haing to variables with the same name. Could you please elaborate, I dont see how this would enable any motors that woulnt be enabledin the default code.
Thanks
James
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 22-01-2006, 22:32
Rookie Year: 1234
Thanks
James
Ignore the rest of my post other then this:
The rest had nothing to do with your problem.
Unread 22-01-2006, 22:36
FRC #5279
Oh alright, I see what you meant in you origianal post sorry about that
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 22-01-2006, 23:48
FRC #2429
Yep. I don't want people loading my code on their 'bot with the possibility that some motor is going to take off on them.
-Kevin
Kevin Watson
http://kevin.org
Unread 23-01-2006, 04:26
Hi
Im using the FRC 2006 Default_code when i add kevin's serial port code the FRC is not geting the right Data from the OI ..
can u tell me who to edit the "Serial_Char_Callback" function to recive Data
from the ttl port
tried to do it with kevin's serial code and it didnt work
thanks
Gyroscope Code Kevin Watson Programming 65 01-03-2008 23:46
Analog-to-Digital Converter Code Kevin Watson Programming 29 17-02-2008 13:07
Trying to import Camera code into program without. Kingofl337 Programming 1 18-02-2005 00:43
Problem running compiled code jskene Programming 10 23-01-2005 21:13
Wierd gyro code problems...pls help Salik Syed Programming 4 14-03-2004 01:29
