Go to Post Without mentors, you wouldn't even be participating in FIRST. Your team wouldn't exist, and FIRST as a program wouldn't exist. If it did, it'd just be another form of a science fair. - Cory [more]
Unread 22-01-2006, 18:21
Gdeaver Gdeaver is offline
FRC #1640
FRC easy-c vex encoder function?
Our team has not yet brought easy-c up yet but, my understanding is that the Vex encoder functions are not included with the FRC version of the software. If this is true is there anyway to import them? Our team would like to use them if possible.
Unread 23-01-2006, 06:49
Dan Larochelle Dan Larochelle is offline
FRC #0040 (Pioneers)
Rookie Year: 1993
Dan Larochelle has a spectacular aura aboutDan Larochelle has a spectacular aura about
Re: FRC easy-c vex encoder function?
The Optical Encoder function block in easyC for FRC works the same was the Vex encoder block in easyC for Vex. This means you can plug your Vex encoder into your FRC controller and it will work as expected. Obviously you will have to change the PWM connector from male to female or use an adapter PWM cable that changes the gender in order to plug it into the FRC controller.
Unread 23-01-2006, 08:03
AKA: Brad
#0190 ( Gompei and the Herd)
The palette of EasyC has blocks for an Optical Quadrature Encoder (2 channel output with direction sensing) and an Optical Encoder (VEX single output encoder).
The Optical Encoder was put there to support the VEX encoders but simply counts edges and can actually be used with any single output encoder you might have. In fact, you can use it to count pulses from any device including limit switches.
Just remember that the encoder must be used with inputs 1-6 and not any of the others.
Brad Miller
Robotics Resource Center
Encoder Code Kevin Watson Programming 47 18-02-2008 12:56
VEX UltraSonic and Encoder SOLD OUT... Chris_Elston Electrical 5 09-01-2006 13:22
Vex Easy C Demo Ken Delaney 357 FIRST Tech Challenge 3 22-08-2005 13:47
TTL port to a serial port on a demo board ImmortalAres Programming 16 09-07-2005 23:44
RoboEmu2(code simulator)--now with C! rbayer Programming 23 17-02-2005 09:17
