Go to Post Engineering is a balance between best performance, best cost, and best use of time. - GeorgeTheEng [more]
Unread 20-01-2006, 21:29
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
AndyMark Omni Wheels
Who out there have used the AM wheels?
We are thinking about using them but we can't decide which ones to order.
Which ones have you used and what did you think of them.
1) Omni wheel material
A) Rubber
B) Delrin
C) Neoprene
2) Wheel material
A) Aluminum
B) Polycarbonate
Thanks is advance
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 20-01-2006, 21:38
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Re: AndyMark Omni Wheels
I'd ask the builders of this.
Richard Wallace
since 2003
Unread 21-01-2006, 00:29
Gary Bonner Gary Bonner is offline
FRC #3974
Gary Bonner has a spectacular aura aboutGary Bonner has a spectacular aura about
We used the 6” aluminum wheels last year without much luck. On the 6” wheel, the rollers are spaced angularly too far apart. The robot bounces up and down as the wheel turns and alternately rides up onto a single roller and then down onto two adjacent rollers. The 8” wheel has more rollers, but I don’t know if it rides any more smoothly. I believe some teams put two wheels together and staggered the rollers to address this, but that doubles the weight of your wheel.
The other issue we had was with the rollers themselves. The acetal rollers rolled freely, put provided very little forward traction. The EPDM rollers had very good forward traction, but the roller would flex and wedge in its slot, which would prevent it from rolling. The neoprene rollers weren’t available when we ordered last year, so I don’t know how they will perform.
Although I’ve only seen the molded plastic wheel picture on the website, it looks to me to be much better. They have more and wider rollers, and the rounder wheel profile should turn more freely. I don’t know how freely the rollers turn, but it doesn’t look like their flexing would be a problem.
Unread 22-01-2006, 22:02
Ben Piecuch Ben Piecuch is offline
Bengineer
Ben Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond repute
We just purchased a pair of 8" AM plastic molded Omni-wheels. They should be arriving this week, and we'll get a chance to play with them on last years' robot. I talked with Andy himself and asked a few questions, which is what eventually swayed me to the plastic ones. We choose the plastic omni's for the following reasons.
1) Only one wheel per side, no need to double up. This reduces cost, weight, and volume. (Can you get a better solution?)
2) 1.875" bolt pattern, as opposed to the 2.25" on the AL ones. No adapter needed for the AM aluminum sprockets.
3) Hopefully, similar traction on the carpet and the ramp. (I don't know how the more narrow roller from the AL omni's would fare on the ramp.)
Unfortunately, I won't be able to do a head-to-head comparison of the AL omni's to the plastic omni's. But, I can certainly let you know, relatively, how they compare to the 8" skyways.
And, if my word isn't enough, here's one of Andy's direct responses. (Copied without permission, though I don't think he'll mind...)
"I think that the plastic omni-wheels are a improvement to the aluminum-based wheels. We saw many rollers crack and break last year because they stick too far out from the aluminum body of the trick wheel. That is why we made a smaller pulley on the new plastic omni wheel. These rollers will last longer, although they are the same duromter. They won't dig into the carpet as much as the trick wheels, but they still will have ok grab on the carpet. We need to do some tests on this... ug, I need more time for that."
BEN
Team 228
Unread 23-01-2006, 08:56
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
I highly suggest the plastic omni-wheels to anyone considering between our two styles.
Simply put, the plastic omni-wheel is an upgrade of the Trick Wheel. Gary is right in his post... the Trick Wheels have too much spacing between the rollers and the rubber rollers don't hold up as well as they should because they have a diameter that is too large.
The "Omni Wheel" is VERY robust. They are made from two halves of molded polycarbonate with a 10% fiberglass filler. All wall thicknesses of this mold is over 0.1". The rollers are molded instead of cut like the rollers on the Trick Wheels. They spin easier sideways, while still providing traction forward and backward. Each roller on the Omni-Wheel rides on a pair of brass eyelets, which are bearings for the captured dowel pin. Trick wheels don't have these brass eyelets.
We strongly considered discontinuing the "Trick Wheels" this year, but since many people bought them last year and during the off season, we had to keep them on our product listing. We will look to discontinue them this summer, unless the demand keeps up.
It is no fluke that we priced the Omni-wheels lower than the Trick wheels. They are lower simply because we want to sell them more than the Trick wheels. Some people, I believe, are choosing Trick Wheels because they think they are paying more for a better product, but this is not true... the Omni-wheels are simply a better omni-wheel than the Trick Wheel.
I am excited to hear from people who have started to use our plastic Omni-wheels to see what their opinions are.
Sincerely,
Andy
Unread 23-01-2006, 09:07
bombadier337's Avatar
bombadier337 bombadier337 is offline
1337 U53R
AKA: Shaver
None #1541 (MidloCANics)
bombadier337 is just really nicebombadier337 is just really nicebombadier337 is just really nicebombadier337 is just really nice
Send a message via AIM to bombadier337
Are the hubs for the trick wheel compatible with the new omni wheels? We already have everything based off of 1/2 drive shaft, but if we can easily change we probably will.
Midlothian High School - Team 1541
2005 Radioshack Innovation in Control - NASA/VCU Regional
2005 Rookie Inspiration - NASA/VCU Regional
Unread 23-01-2006, 09:27
As of tomorrow, all of the 1/2" bore, 1/8" keyway hubs for the Trick Wheels will also fit the Omni-Wheels (and Traction Wheels). These are being finished today, and they will be sent out as hubs for either wheel.
This has not been reflected on our website yet.
Andy B.
Unread 23-01-2006, 09:33
1337 U53R
AKA: Shaver
So are you making a new hub, or is it a modifiction to the wheel?
Unread 23-01-2006, 16:09
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
Andy,
Unfortunally I speced out the trick wheels for my team this year as our first omni's and after the fight with the other engineers I belive I will be looking really red if they perform as some have said, as we have not yet gotten them could I return them for the new style, or if the shipment hasent left yet is there any way to change them around?
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
I like them with the delrin as a omni. As I mentioned recently in another post watch your weight balence when you use them. To much over the omnis can cause the neoprene wheels to bottom out and put metal in contact with the carpet. It will also effect the handeling.
Pete
Unread 23-01-2006, 18:44
Kyle Love's Avatar
Kyle Love Kyle Love is offline
Support STEM Education
FRC #3301 (Jay County Robotics)
Kyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond repute
I agree with Andy, the AM Trick-Wheels are cool...but the Omni's give you a better looking and performing bang for your buck...and they are cheaper!
Kyle Love
Teams I've been on:
Team 45 - The TechnoKats - Student/Leader/Driver 2004-2007
Team 1646 - Boiler Precision Guessworks - Mentor 2007-2011
Team 3301 - Jay County Robotics - Teacher 2011-Present
Unread 25-01-2006, 23:54
downhillpat241 downhillpat241 is offline
Drive/Chassis Engineer, Bouncer
AKA: Pat Sullivan
FRC #0241 (Pink Wheeled Revolver)
downhillpat241 will become famous soon enoughdownhillpat241 will become famous soon enough
Yeah...we bought the trick wheels. 8 inch with delrin. Just came in today. havent really played with them yet...will post result when robot gets running...
Also ordered the adapter kit for "the beast motors" I will post on that also.
"Those motors are freakin' DIESEL!!!" (in reference to the mini bike motors...)
omni wheel instead of mecanum wheels Leav Technical Discussion 4 15-01-2006 18:53
Omni Wheels Survey Ryan F. Technical Discussion 44 04-05-2004 13:24
Lots of Wheels and F = u x N archiver 2001 17 23-06-2002 23:37
