Go to Post Hard work is a necessary prerequisite for luck. - Ian Curtis [more]
Unread 23-01-2006, 09:44
Mr.D's Avatar
Mr.D Mr.D is offline
Randy Decker
FRC #0829 (Warren Robotics "The Digital Goats")
Mr.D is just really niceMr.D is just really niceMr.D is just really niceMr.D is just really nice
#6 Battery Quick Disconnects
Where can you purchase additional #6 quick disconnect connector #6331G1?
Randy Decker
Computer/Networking Technology, PLTW DE/IED,
and Electronic Systems Technician Teacher
Walker Career Center
Indianapolis, IN
www.warrenrobotics.org
2008 Boilermaker Regional J&J Gracious Professionalism Award
2008 Bloomington Vex Champion
2007 St. Louis Regional Champion
Unread 23-01-2006, 10:10
ntroup's Avatar
ntroup ntroup is offline
WildStang!
None #0111 (Wildstang)
ntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud of
Re: #6 Battery Quick Disconnects
Although they aren't attached to the 12-inch #6 wire, we get the connectors, themselves, from PowerWerx.
http://www.powerwerx.com/category.asp?CtgID=3070
Hope that helps,
Nate
Unread 23-01-2006, 10:40
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
these are made by Anderson power products, Most good electrical supply houses will carry their goods, so I would check locally with places that deal with that type of thing, This may save you some shipping time, or get you a new sponsor!
the number you will need to ask them for is
6331g1
SB 50 series
find other part numbers, or different housing colors(blue,yellow,green,orange) NOTE: only like color connectors will mate with one another, IE cannot put a blue and a red together so for additional ones like the kit only order part 6331g1 as per the frist KOP List, Thanks BrianBSL here part number list
To find your local Anderson dealer go Distributors list
Also it is possible to open the crimp on the connectors they give us, with something to spread the sides of the crimp apart you can then pick/pull the wires out and re crimp(if you have proper equipment, if not crimp and solder! ) so as to make one less joint in your electrical system.
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
Unread 23-01-2006, 11:36
BrianBSL BrianBSL is offline
FRC #0190
BrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud of
Originally Posted by Justin Stiltner
find other part numbers, or different housing colors(blue,yellow,green,orange) here part number list
Just a note that each color is keyed differently, you can not mix and match red's and blue's, etc.
My posts represent my personal views only, and do not represent the views of either my team, Team 190, nor its primary sponsor, Worcester Polytechnic Institute.
Why MUST the 7.2v battery be attached to operate servos on the RC? Mike Rush Control System 17 06-02-2004 18:57
Quick release battery connector and 120 amps n[ate]vw Electrical 6 18-01-2003 23:41
Off-topic battery stuff. FotoPlasma Electrical 4 06-01-2003 12:19
Voltage Range of Analog Inputs Ulibrium Electrical 21 15-02-2002 14:11
connecting to the battery ahecht Technical Discussion 1 25-01-2002 17:15
