Go to Post There's nothing wrong with the loader [dividing by zero], John just misses us 229'ers and wanted everyone to know :-P - Jay Trzaskos [more]
Unread 21-01-2006, 08:36
Capozzi Capozzi is offline
FRC #1251
Capozzi is an unknown quantity at this point
i am a newbie at the camera
OK, i am a complete newbie at the camera software and i have no idea what i am doing. i went through the LabVIEW tutorials and that didn't do much. I used the examples on another forum to see if i could understand what i am doing but that was very little help. http://www.chiefdelphi.com/forums/showthread.php?t=41214
i cant even get the camera to take a picture or show me what its looking at. after fiddling around with LabVIEW i see it as a very easy interface for basic programing. if any one could give me a step by step process to get LabVIEW to connect to the camera i will greatly appreciate it.
Unread 23-01-2006, 15:30
JJMax7 JJMax7 is offline
None #0918 (Circuit Chargers)
Team Role: Driver
JJMax7 is an unknown quantity at this point
Send a message via AIM to JJMax7
Re: i am a newbie at the camera
Use Easy C instead.
Unread 23-01-2006, 15:49
jdhawg's Avatar
jdhawg jdhawg is offline
Programmer/Mentor/Parent. Pick One
AKA: Jack D Higgs
FRC #0364 (Team Fusion)
jdhawg will become famous soon enough
First, are you getting power to the camera? Second, do you have both serial connections hooked up? (That's a no-no, by the way)
You have to get the guide from kevin.org or usfirst.org and follow it STEP-BY-STEP. Trust me, skimming over it without carefully reading and following the instructions to the letter will just leave you frustrated.
"Opportunity is missed by most people because it is dressed in overalls and looks like work." - Thomas A. Edison
"In the professional world, spelling mistakes, grammatical shortcuts, leet-speek, and misused verbiage are not interpreted as signs of cute, efficient communications. They are indicators of illiteracy, inefficiency, unprofessional behavior, and sloppy work habits." - Dave Lavery
Unread 28-01-2006, 10:56
Burning Ice Burning Ice is offline
Resident Pyro
FRC #1506 (Metal Muscle)
Burning Ice is an unknown quantity at this point
To get a feel for the software......start by using last years cmucam2 software and play with that....its super easy to use and youll have an easier time problem solving....
try playing with
http://www.cs.cmu.edu/~cmucam/cmucam2/CMUcam2GUI.zip
labview is pretty advanced and somewhat hard to use....
good luck
How To Use the Google Camera generalbrando Kit & Additional Hardware 2 07-02-2006 16:00
Camera pointing error? Craig Putnam Programming 14 21-01-2006 02:52
Scripting Setup and the Camera + Serial Port Drivers CJO Programming 22 11-01-2006 17:42
Unresponsive camera neilsonster Programming 9 17-02-2005 08:51
CMUCam2 Camera Code - Are important parts commented out? Mr. Lim Programming 4 14-01-2005 12:11
