Go to Post Thinking about this game within the confines of previous years will limit you. - Gregor [more]
Go Back   Chief Delphi > Technical > National Instruments LabVIEW and Data Acquisition > LabView and Data Acquisition
Unread 23-01-2006, 15:50
Mike Bortfeldt Mike Bortfeldt is offline
FRC #1126 (& 1511)
Mike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud of
Re: Labview keeps freezing
SHerpich,
We've observed the same problem. When we first installed LabVIEW, we were able to grab frames without any problems. The last time we tried, we saw the same problem you described. We would always be able to grab at least 1 frame, and sometimes several, but then the progress bar would indicate a frame grab in progress and once it would get to the end, there was a pause (several seconds), no new frame displayed, but the progress bar would start over as if it was acquiring another frame. Our workaround is to upload the camera parameters in between every frame grab (even if nothing has changed). I'm not sure why that works or if that will work for you, but give it a try.
You also may get a better response if you put this question in the LabVIEW forum.
Mike
Example LabVIEW Apps - Dashboard, CMUcam2 and Motors Russ Beavis National Instruments LabVIEW and Data Acquisition 9 21-01-2007 17:19
LabVIEW Com Port Error 354.FIRST LabView and Data Acquisition 4 18-01-2006 18:43
National Instruments LabVIEW and Data Acquisition Forum Danny Diaz National Instruments LabVIEW and Data Acquisition 1 16-01-2006 13:20
COM port settings for CMUcam labview testing and programming pwilczynski Programming 1 15-01-2006 15:09
National Instruments LabVIEW & Data Aquisition Forums Brandon Martus Announcements 0 22-11-2005 21:12
