Go to Post It's not fair. it's not right, but stuff like this happens. If you don't get picked for finals tomorrow, get in those stands and cheer for those who did. Remember, this is FIRST. - wilsonmw04 [more]
Unread 23-01-2006, 18:22
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Our pump has problems!
Did you notice the compressor getting very warm? Did it take a long time to get up to pressure? My guess is you have it running in reverse. Try switching the wires or the relay direction.
Unread 23-01-2006, 19:27
reverse? I though the pump was bi-directional?
check your fittings all around with a little soapy water. Or pump up the system with a pressure gauge attached, turn the pump off, and watch the pressure - you should not be able to see the needle on the gauge move in less than a minute or two.
Unread 23-01-2006, 19:50
Derek Bessette's Avatar Unsung FIRST Hero
Derek Bessette Derek Bessette is offline
FRC #4976 (Rebels)
Derek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond repute
I would try disconnecting the entire circuit after your pressure gage and pressure switch. Once you have done this plug the open end. If you are using tubing, a t-fitting with two ends connected with a single loop of tube works well as a plug.
Try your compressor using this setup. This will help determine whether your problem is a leak or actually with the compressor.
For instance, if the pressure goes up to 120 in this situation, you would know that you had a leak somewhere. If the pressure still stops at 75 psi then you need to start looking at your compressor.
Hope this helps.
Derek Bessette
Team 4976 - GDHS Rebels
(Formerly Team 1114 and 3571)
Unread 23-01-2006, 20:15
Stephen Kowski's Avatar
BSEE, MSEE, JD
AKA: employed
make sure are your components are running in the correct direction especially the regulators....(hint: turn them upside down there is normally an arrow indicating the path air will flow)
Labview problems and code problems ajsetter Programming 25 18-01-2006 17:07
Robot Rodeo - fixing control problems Gary Dillard Off-Season Events 7 26-10-2004 00:46
Do you all have problems with.... Munkaboo Website Design/Showcase 19 03-03-2003 19:51
Radio problems -- not archiver 2000 1 23-06-2002 22:23
Pneumatics pump allowed on robot? bigqueue Pneumatics 5 06-01-2002 12:30
