Go to Post Do I think the bar is too high? I think impossible dreams and lofty goals are a key part of FIRST; the "top" being extremely far away only pushes people farther. - Chris is me [more]
Unread 20-01-2006, 23:34
team1500 team1500 is offline
FRC #1500
team1500 will become famous soon enough
Our Camera runs away from the light?!?!?
Hopefully you guys can help us with a problem we are having the servo's on the CMU Cam seem to be reversed because they alway go away from the light instead of tracking towards it I read in one of the other posts that some of the teams had this problem last year however I could not find a way to fix it.
Any help would be appreciated
Thanks
Brad
Unread 20-01-2006, 23:37
bombadier337's Avatar
bombadier337 bombadier337 is offline
1337 U53R
AKA: Shaver
None #1541 (MidloCANics)
bombadier337 is just really nicebombadier337 is just really nicebombadier337 is just really nicebombadier337 is just really nice
Send a message via AIM to bombadier337
Re: Our Camera runs away from the light?!?!?
You could try flipping the camera upside down in the pan/tilt box. If it was mounted incorrectly the first time it would cause something like that.
Midlothian High School - Team 1541
2005 Radioshack Innovation in Control - NASA/VCU Regional
2005 Rookie Inspiration - NASA/VCU Regional
Unread 20-01-2006, 23:40
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
There are also two #define's in the tracking.h file of the camera tracking code by Kevin Watson that specify the sign (+ or -) to be used when tracking. If you locate these two and flip them, you will be able to make that correction in software instead of in hardware.
Unread 21-01-2006, 00:03
iBheat's Avatar
iBheat iBheat is offline
FRC #0418 (Lasa Robotics)
iBheat is on a distinguished road
If you have the servos connected to the CMUCam board then you just have to jump the pan/tilt reverse jumper but if you are using the RC then you need to edit the code in tracking.h.
// If your camera suddenly moves away from the target once
// it finds it, you'll need to change the sign on one or
// both of these values.
#define PAN_ROTATION_SIGN_DEFAULT -1
#define TILT_ROTATION_SIGN_DEFAULT +1
Unread 21-01-2006, 00:09
FRC #1500
Alrighty Thanks guys
We'll have to give those a try tomorrow.
Brad
Unread 21-01-2006, 15:44
stephenthe1 stephenthe1 is offline
stephenthe1 is on a distinguished road
"If you have the servos connected to the CMUCam board then you just have to jump the pan/tilt reverse jumper"
I'm having this problem, how do you go about switching this jumper, and where is this jumper located? (Or how do I switch the pwm cable electronically?)
Unread 21-01-2006, 18:14
Joe Hershberger Joe Hershberger is offline
National Instruments
AKA: jhersh
FRC #2468 (Appreciate)
Joe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to all
Have you looked at the documentation for the camera?
Have a look on pave 17 of the CMUCam2 Workbook.
-Joe
Unread 23-01-2006, 11:48
-Joe
perfect, thanks
Unread 23-01-2006, 14:03
tribotec_ca88's Avatar
tribotec_ca88 tribotec_ca88 is offline
FIRST-a-holic
AKA: Camila Fitzgibbon
FRC #1382 (Tribotec Team)
Team Role: Student
tribotec_ca88 is just really nicetribotec_ca88 is just really nicetribotec_ca88 is just really nicetribotec_ca88 is just really nicetribotec_ca88 is just really nice
Send a message via ICQ to tribotec_ca88 Send a message via MSN to tribotec_ca88 Send a message via Yahoo to tribotec_ca88
I strongly recommend changing the following values first...(Found on Tracking.h) from:
to
#define PAN_ROTATION_SIGN_DEFAULT +1
#define TILT_ROTATION_SIGN_DEFAULT -1
Our team was having similar issues and in the end we found out all we had to do was invert the +/- signal...lol...
1382 Tribotec Team - Brazil
2005 NJ Regional GM Industrial Design Award
2005 NJ Regional Website Excellence Award
2004 NJ Regional Semifinalists
Unread 23-01-2006, 17:42
cmurdoch cmurdoch is offline
AKA: Caroline Murdoch
FRC #1208 (Metool Brigade)
cmurdoch is on a distinguished road
we're having the same problem, but we've tried switching the values in tracking.h and it didn't work. Is there some reason it might not be recognizing the new values?
Unread 23-01-2006, 19:15
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
Are you using the Bells and Whistles camera code or the stripped down version? If you're using the Bells and Whistles version, I believe the values in tracking.h will normally only come into play the very first time you run the code. The first time you run the program, all the parameters get saved into EEPROM. To get it to use the the values from tracking.h, you will need to go into the tracking menu, and tell it to reload the default values.
If you're using the stripped down version, then I have no explanation why it's not working.
Unread 23-01-2006, 21:01
Bharat Nain's Avatar
Did something stupid today. The PWMs were switched. I debug it one axis at a time and realized that. I switched the Pwms for pan and tilt and they worked like a wonder. Little things can drive you crazy.
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 27-01-2006, 13:06
Ryan O's Avatar
Ryan O Ryan O is offline
FRC Eclipse Plug-in Developer
no team (FRC Eclipse)
Ryan O is an unknown quantity at this point
Send a message via AIM to Ryan O
Thanks
Brad
If you are using labview when this happens, it is only becxause labview is crewy. I just turned the servo horn around for labview and put it back for Kevin's code and it worked fine.
Unread 28-01-2006, 10:39
Burning Ice Burning Ice is offline
Resident Pyro
FRC #1506 (Metal Muscle)
Burning Ice is an unknown quantity at this point
Your Camera is upside down....I had the same problem....and i tore it apart and reassembled the camera multiple times......and found that having the camera upside down does that......
Any other questions, feel free to ask and ill help the best i can..
feel free to email me at
Johnbk14@gmail.com
Unread 29-01-2006, 11:52
itzrobz itzrobz is offline
None #0333
itzrobz is an unknown quantity at this point
i have the same problem. I am using labview. can anyone tell me how to reverse the pan?
camera trouble,cant tell the green-light from regular white light Nimmy Programming 26 14-01-2007 14:53
pic: camera locked on light 143ft away!!! kborer22 Extra Discussion 18 08-07-2006 14:49
How To Use the Google Camera generalbrando Kit & Additional Hardware 2 07-02-2006 16:00
A light on top of the camera? xFlashbacksx Technical Discussion 5 22-01-2005 12:04
How many users does it take to change a Light Bulb? Matt Attallah Chit-Chat 4 04-09-2004 20:59
