Go to Post A lot of the time in FIRST it's not what you have when you enter the program, but what you gain from being in it. - Elgin Clock [more]
Unread 23-01-2006, 19:25
Nicole_Ypes Nicole_Ypes is offline
Nicole Ypes
FRC #1547 (Waldo)
Nicole_Ypes is an unknown quantity at this point
Send a message via MSN to Nicole_Ypes
Exclamation Dashboard Distress
Help! I can't figure out how to use dashboard or get a proper connection on my computer. Can anyone help me?
Unread 29-01-2007, 13:18
Katie Reynolds Katie Reynolds is offline
no team (NEW Apple Corps)
Katie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond repute
Send a message via AIM to Katie Reynolds Send a message via Yahoo to Katie Reynolds
Re: Dashboard Distress
Hi Nicole,
What problems, specifically, are you having? The more information you can provide, the better we'll be able to help you solve your problem!
For future reference, there is an excellent post here on "How to Post a Question" in the Programming section. Also, you can use CD's handy search feature to see if the question you want to ask has been asked already. Linked here is a quick search for "Dashboard".
Hopefully, this will help answer your question. If not, don't be afraid to come back to this thread and post again about your problem. But to help us help you, please include a few more details so we can answer your question as fully as possible!
Team #93 - NEW Apple Corps
Student - 2001-2004
Team #857 - Superior Roboworks
Mentor - 2006-2009
Unread 29-01-2007, 13:52
There are a couple of Dashboard versions floating around.
What's the name of the one you're trying to get working?
One Dashboard released a few years ago by Innovation FIRST is the simplest to run.
http://www.ifirobotics.com/dashboard_viewer.shtml
Another is available through the Labview application that came in this year's or last year's Kit-of-Parts.
Both require you to connect your PC to the Dashboard output on the Operator Interface (OI). From either program you will have to select the proper serial port your PC is using - typically COM1 if it is a built-in serial port, and COM3 or 4 if you are using a USB-to-serial converter instead.
The port has to be set to the correct data rate for the OI Dashboard output: 19200 baud, No Parity, 8 data, 1 stop
There is more to it, but let us know what you're using first.
2004 Dashboard Protocal vs 2005 Dashboard Protocal Kyle T Programming 4 14-03-2005 22:19
A More Mobile Dashboard Astronouth7303 Programming 3 01-02-2005 21:38
Weird Output from Dashboard Port Ian W. Programming 9 06-03-2004 21:33
New dashboard packet spec Ameya Programming 2 08-01-2004 19:59
Dashboard Viewer Khalicl13 Technical Discussion 8 15-06-2001 23:36
