Go to Post MR. KAMEN! TEAR DOWN THIS WALL! - Briansmithtown [more]
Unread 23-01-2006, 19:50
Derek Bessette's Avatar Unsung FIRST Hero
Derek Bessette Derek Bessette is offline
FRC #4976 (Rebels)
Derek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond repute
Re: Our pump has problems!
I would try disconnecting the entire circuit after your pressure gage and pressure switch. Once you have done this plug the open end. If you are using tubing, a t-fitting with two ends connected with a single loop of tube works well as a plug.
Try your compressor using this setup. This will help determine whether your problem is a leak or actually with the compressor.
For instance, if the pressure goes up to 120 in this situation, you would know that you had a leak somewhere. If the pressure still stops at 75 psi then you need to start looking at your compressor.
Hope this helps.
Derek Bessette
Team 4976 - GDHS Rebels
(Formerly Team 1114 and 3571)
Unread 23-01-2006, 20:15
Stephen Kowski's Avatar
BSEE, MSEE, JD
AKA: employed
make sure are your components are running in the correct direction especially the regulators....(hint: turn them upside down there is normally an arrow indicating the path air will flow)
Labview problems and code problems ajsetter Programming 25 18-01-2006 17:07
Robot Rodeo - fixing control problems Gary Dillard Off-Season Events 7 26-10-2004 00:46
Do you all have problems with.... Munkaboo Website Design/Showcase 19 03-03-2003 19:51
Radio problems -- not archiver 2000 1 23-06-2002 22:23
Pneumatics pump allowed on robot? bigqueue Pneumatics 5 06-01-2002 12:30
