Go to Post Finding those students and giving them a lift up out of the sea of apathy that is constantly trying to drown them is one of the reasons I am in my profession. - Ben Mitchell [more]
Unread 23-01-2006, 18:01
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Our pump has problems!
Hi all,
We hooked up our pneumatic system to a cylinder following the basic setup.
Our pump gauge only read until 75psi. The pump also was still on and didnt shut off. I think the switch kicks in at about 115 psi to shut the pump off. anybody else had problems getting the air tanks to reach 115psi? We checked all of our hoses and their was no apparent leak.
Also, can you adjust the switch to shut off the tank at 75psi? If so, how? is it done through the code?
Aloha!!!
Unread 23-01-2006, 18:22
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Our pump has problems!
Did you notice the compressor getting very warm? Did it take a long time to get up to pressure? My guess is you have it running in reverse. Try switching the wires or the relay direction.
Unread 23-01-2006, 19:27
reverse? I though the pump was bi-directional?
check your fittings all around with a little soapy water. Or pump up the system with a pressure gauge attached, turn the pump off, and watch the pressure - you should not be able to see the needle on the gauge move in less than a minute or two.
Unread 23-01-2006, 19:50
Derek Bessette's Avatar Unsung FIRST Hero
Derek Bessette Derek Bessette is online now
FRC #4976 (Rebels)
Derek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond repute
I would try disconnecting the entire circuit after your pressure gage and pressure switch. Once you have done this plug the open end. If you are using tubing, a t-fitting with two ends connected with a single loop of tube works well as a plug.
Try your compressor using this setup. This will help determine whether your problem is a leak or actually with the compressor.
For instance, if the pressure goes up to 120 in this situation, you would know that you had a leak somewhere. If the pressure still stops at 75 psi then you need to start looking at your compressor.
Hope this helps.
Derek Bessette
Team 4976 - GDHS Rebels
(Formerly Team 1114 and 3571)
Unread 23-01-2006, 20:15
Stephen Kowski's Avatar
BSEE, MSEE, JD
AKA: employed
make sure are your components are running in the correct direction especially the regulators....(hint: turn them upside down there is normally an arrow indicating the path air will flow)
Unread 24-01-2006, 07:54
Originally Posted by waialua359
Hi all,
Aloha!!!
There are a few things that could be wrong. Although the pump works in either polarity, it is more efficient and will run cooler when running in the correct direction. It is possible that the wiring feeding the compressor has a loose crimp or that you have a defective breaker which will supply less current to the compressor. The compressor has a pressure relief valve that is designed to pop open at 125-130 PSI that may be damaged and leaking. It is the brass fitting connected to the head of the compressor. Finally, screw fittings should be assembled with Teflon tape (available at any hardware store) to help seal the connection. 90% of the problems with pneumatics are leaks. If you system is already assembled with valves in place, clamp the tubing as it exits the storage tanks and see if the compressor will reach full 120 PSI. Valves sometimes leak especially when installed backwards.
Aloha!
Unread 24-01-2006, 13:00
Jared Russell's Avatar
Taking a year (mostly) off
We had this problem earlier too - it turned out the pressure relief valve in the compressor was damaged. We replaced it and our problem went away.
Unread 24-01-2006, 13:02
waialua359's Avatar
AKA: Glenn
Re: Our pump has problems! *FIXED*
Thanks everyone for your help. It was our regulator.
Labview problems and code problems ajsetter Programming 25 18-01-2006 17:07
Robot Rodeo - fixing control problems Gary Dillard Off-Season Events 7 26-10-2004 00:46
Do you all have problems with.... Munkaboo Website Design/Showcase 19 03-03-2003 19:51
Radio problems -- not archiver 2000 1 23-06-2002 22:23
Pneumatics pump allowed on robot? bigqueue Pneumatics 5 06-01-2002 12:30
