Go to Post The FIRST program is different. It has a different purpose. It isn't superficial, it's results are long term and lasting. I hope that FIRST is still on message. - JohnBoucher [more]
Unread 21-01-2006, 14:01
Windward's Avatar
Windward Windward is offline
FRC #1452
Windward is an unknown quantity at this point
Re: Camera to motor setup
Acutally, I was thinking of mounting the camera on top of the turret, and setting up the motors so that it would automatically swing the turret until the camera reads 0 pan and 0 tilt without any code modification. Would that work?
Unread 21-01-2006, 17:30
It should, but you need to recognize something that might make it work less well than you expect. The camera code doesn't move the tilt or pan servos until the vision target gets "far enough" from the center of the view.
Unread 23-01-2006, 20:29
Windward's Avatar
FRC #1452
What do you mean by this?
Unread 23-01-2006, 22:23
Look at tracking.c in the camera code provided by Kevin Watson. In the servo_track() function, it checks to see how many pixels off-center the target is. Only if it's more than Pan_Allowable_Error left or right, or Tilt_Allowable_Error up or down, does it actually move the servo to recenter the target in the camera's field of view.
So if you want to be as accurate as possible, you need to move the turret to zero the pan/tilt servo values and also cause the mx/my values returned from the camera to match the target pixel values.
Unread 25-01-2006, 17:47
Windward's Avatar
FRC #1452
Originally Posted by Astronouth7303
Closed loop
An encoder is a digital sensor that detects regular "ticks" on a wheel. The purpose of it is to detect either velocity or position. You count ticks and compare them to the time. In this case, an encoder can either be a tooth counter, the banner sensors, or the grayhill encoders.
sorry. I meant gyro.
Unread 25-01-2006, 18:32
devicenull devicenull is offline
Robot? We need a robot?
Rookie Year: 1234
devicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nice
If you mean 127 pan and 127 tilt, then yes, it works very, very nicely
Unread 17-02-2006, 23:24
Bharat Nain's Avatar
Did you or anyone ever get the Camera to Motor setup working?
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 18-02-2006, 00:05
FRC #0701 (RoboVikes)
Our team used a heavily modified version of Kevin's PID code,
basically all you have to do is add another motor to the motor_info data struct, and change the get_encoder_value function so that it returns PAN_SERVO when the argument is 2
now simply call set_pos(2,127)
and set your left and right drive motors to =motor_info[2].pwm+127; and 127-motor_info[3].pwm; (this may need to be change depending on your wiring and robot setup)
you may have to tweak the P, I, D constants
We had it working beautifully until we did some other stuff and screwed it up...
(we used our own custom PID software... but i think i'm gonna switch back to kevins because i can't figure out whats wrong with ours... and I didn't write it so I don't understand it 100%)
Team 701
Unread 18-02-2006, 13:18
Windward's Avatar
FRC #1452
We don't have encoders working and it is far too late to implement them into our bot.
On a side note, we did the zero point method making the servo's and motor values equal to the search value, it works beautifully when we implemented. Basically the human player controls the turret until the "find target" button is pressed. Then the camera re-aligns the turret to aim for the green.
Unread 18-02-2006, 20:29
you don't need encoders, you can fake the system.... just put the camera pan servo value in place of the encoder count, the PID math is the same
Team 701
How To Use the Google Camera generalbrando Kit & Additional Hardware 2 07-02-2006 16:00
Camera pointing error? Craig Putnam Programming 14 21-01-2006 02:52
Scripting Setup and the Camera + Serial Port Drivers CJO Programming 22 11-01-2006 17:42
Unresponsive camera neilsonster Programming 9 17-02-2005 08:51
CMUCam2 Camera Code - Are important parts commented out? Mr. Lim Programming 4 14-01-2005 12:11
