Go to Post The top 3 debates you don't want to bring up in a group of nerds: Mac vs PC vs Linux, Best Programming Language, and Best CAD Program. - EricH [more]
Unread 23-01-2006, 23:23
Joshua Lynn Joshua Lynn is offline
FRC #0423 (SEC Mechanical Mayhem)
Joshua Lynn is on a distinguished road
Denso Window Motor gear profile?
The models in the KOP for the Denso Window Motor RH and the Large Flange which should mate to the gear of the motor seem to have different profiles.
Does Anyone know which is accurate?
I need to project the geometry of the gear profile onto another part for cutting. I Started with the large flange since I figured It had the tolerances to fit already applied.
Thanks in advance
[IMG]denso.jpg[/IMG]
Unread 23-01-2006, 23:34
ebmonon36's Avatar
ebmonon36 ebmonon36 is offline
AKA: Eric Bredehoeft
FRC #1018 (Robodevils)
ebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud of
Send a message via AIM to ebmonon36
Re: Denso Window Motor gear profile?
If your window motor is like the one I have, they are completely different motors than the model of the one in the kit of parts and more like the one in the spec sheets on FIRST's website, making the profile of the gear on the shaft much different. The motor I have only has 6 teeth on the gear.
Eric
Unread 23-01-2006, 23:57
Biff Biff is offline
AKA: Tom Cooper
#1227 (Techno Gremlins)
Biff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the rough
It's new this year. Plastic shaft 0.645" dia with six "square" teeth 0.156 wide and (0.780 - .645)/2 tall The toothed part is about .7" and the shaft center which I assume doesn't rotate comes out to 1" from the plate. Three mounting holes 2.329 approx on the small leg of the triangle and 4.047 approx on the long leg shaft center is 2" from the top of the long leg and 2.22 from each of the ends of the smaller leg. The 5/8" window motor shaft mount fits right on the new drive and the whole assembly is lighter. I haven't checked free speed or the new mass yet. BTW check all first inventor parts that you plan to take to get mill work done on as I didn't last year with it's new window motor, I had to do a lot of hand work to get the proper fit on the coupling we had machined. Wiring it is going to be fun also as it looks to be a water proof mating item. With the pins deep in a plastic receptacle.
pic: Team 1293's Window Motor Drivetrain 2 Billfred Robot Showcase 18 03-02-2005 23:33
'Fix It Window' and Programming.... JMac Programming 19 25-01-2005 18:57
window motor solid model Redhead Jokes Inventor 0 04-02-2003 14:23
Nippon Denso Window Motor Specs RichardBCR Motors 13 26-01-2003 07:01
Looking for window kit parts archiver 2000 2 23-06-2002 22:50
