Go to Post The life-status of an equine animal has never affected the degree of corporal punishment administered on this BBS. - Rick TYler [more]
Unread 17-01-2006, 21:09
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
Question fusing ends of latex tubing
We are attempting to make a ball conveyor using the latex tubing supplied in the kit of parts. What successful methods have been used in the past
We applied some rubber cement from a tire patch kit on the outside walls and then slide it into some heat shrink tubing. A heat gun and 2 hours later and it appeared to be holding well ... then it came loose
Does splicing work with thread wound around???
Thanks in advance,
APS
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
Unread 17-01-2006, 21:20
Paul H's Avatar
Paul H Paul H is offline
Renegade of Funk
AKA: Paul Huston
FRC #0033 (Killer Bees)
Paul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant future
Send a message via AIM to Paul H
Re: fusing ends of latex tubing
You could try melting it to itself, that's how we fused the Polycord belting we used in 2004.
-Paul
Unread 17-01-2006, 22:42
evolution's Avatar
evolution evolution is offline
FRC #0418 (LASA Robotics)
Team Role: Student
evolution will become famous soon enough
I believe you're reffering to the surgical tubing. I haven't personally done this, but this is what I remember my coach telling me last week to make a loop out of surgical tubing - please get a second opinion to confirm this before you try it:
Find a sort section of a cylindrical rubbery material that you can stretch and pull the opposite ends of the surgical tubing over (some small diameter rubbery material). IF I remember right, you apply a little heat to the joint, the surgical tubing melts a bit and permanently turns sticky at the joint.
Unread 18-01-2006, 00:06
The heat gun was used initially to attempt to fuse the ends and ended up making a stinking mess It got hot and gooey but would never fuse.
edit: rereading your post are you speaking of some sort of flexible insert which the surgical tubing fuses to upon heating?
APS
Founder FRC 499
Unread 18-01-2006, 02:26
evolution's Avatar
Team Role: Student
Getting the surgical tubing to stick to itself is extremely difficult. But if you have the flexible insert inside (which is larger in diameter than the inside of the surgical tubing, but by just a little), the surgical tubing should get gooey and fuse with the insert.
It will definitely stink - same thing that happens when you burn the end of bungee cord to keep it from fraying. Now, I don't know if the stuff being produced is toxic. That's something to find out.
That's my understanding based on what my Coach explained with the fused piece he pulled out from some years ago.
Unread 18-01-2006, 03:22
Electrical Engineer
Rookie Year: 1995
Thanks in advance,
APS
Andrew,
I do have a method of making a loop of latex tubing but the procedure is rather complicated to explain without pictures, et cetera.
I strongly suggest that you use polycord for this application.
If you find that you really need to use latex, please repost here or PM or email me and I'll try and walk you through it.
Regards,
Mike
Mike Betts
As easy as 355/113...
Unread 18-01-2006, 06:03
Kirk Kirk is offline
FRC #0254
Kirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud of
Send a message via AIM to Kirk
Check out McMaster. Endless Belts They come in prejoined lengths from 7 - 60" diameters by 1/4" increments. You can buy the stuff in bulk but the tool to fuse the ends is rather expensive ($450-$500 from what I have seen). Just another option.
Kirk
Unread 24-01-2006, 03:32
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
Speaking of...
Does anyone know the initial tension percentage for McMasters urethane belting? I see Small parts lists 8% for their polycord stuff, by McMaster has no such number. How do you know what length to purchase or make?
$4 a foot is insane for the polycord!
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Unread 24-01-2006, 06:40
Stephen Kowski's Avatar
BSEE, MSEE, JD
AKA: employed
Originally Posted by Travis Covington
Speaking of...
from what i have been reading i am fairly confident that this is belting from fenner drives, and I am not sure about the answer to your other question but their website seems to be a great resource.
Unread 24-01-2006, 12:05
Engineering Mentor
FRC #0254
Turns out the mcmaster stuff is 10%.
-Travis Covington
Unread 24-01-2006, 12:24
Woodie Flowers Award
Ken Patton Ken Patton is offline
purple
FRC #0051 (Wings of Fire)
Ken Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond repute
polycord
A couple of people have already mentioned that polycord is great for this application. I agree, it holds together really well when you fuse the ends properly, and it makes a great ball transport belt. Better than latex tubing imho.
I remember back in 2002? when one of the east coast teams (19 maybe?) had a cool hot-wire polycord cutter. The hot wire (hooked up to a battery) melted the cord and you could then immediately push the two ends together to fuse them. Does anyone remember the specifics of that device?
When we tried to make a belt out of latex tubing before, we tightly wrapped thin twine around the ends of the tubing which were pushed on to a short cylindrical device (I *think* we used a bolt?). It didn't work all that well...
Ken
Unread 29-01-2006, 21:06
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Yeah, we tried heating and it did nothing other than make a gooey smelly mess.
Does anyone know the exact size/spec on the surgical tubing in the KOP and where to get it? Is it the same as Latex tubing from McMaster?
Also, would it be bad if we just tied the ends in a knot? Seems to work okay.
Unread 29-01-2006, 21:50
has anyone tried epoxy? super glue (CA glue)?
Unread 29-01-2006, 21:58
We have abondonded this idea for the time being. We are looking at the shelf liner or carpet runner no slip underlayment material. It seems to have good tack for the poof ball and we will just sew the ends together. The only concern is how much tension to give it and how well the seam will hold. I'll probably need to talk to the home economics teacher for how to sew ends of a stretch fabric so that they won't tear or rip
Anybody have a good use for the six years worth of surgical tubing in my shop. I think I'll post that as available on the CD swap
APS
Founder FRC 499
Unread 30-01-2006, 00:16
occra 23.
AKA: ryo
None #1481
we found a couple zipties with a couple inches of overlapped tubign worked well. depending on what kind of pulleys you are plannign to use. except i know ducttape isnt legal but is zipties other than organizing wires? i dunno. but zipties do rip into the tubing after a lot of use espescially on small pulleys. on larger diameter pulleys less flex in the tubing=less wear. and the more zipties the less strain on each point the tubing is held by ties. and so well... be ready to replace them every day. but not much more than that.
telescoping arm CharlieWilken Technical Discussion 45 26-01-2004 22:22
Can you use other tubing? Skabana159 Pneumatics 2 06-02-2003 22:04
latex tubing rules?? Christina Technical Discussion 4 21-02-2002 18:43
Legality of steel tubing. newy Rules/Strategy 3 01-02-2002 09:16
does small parts sell rectangular aluminum tubing mnkysp6353 General Forum 2 09-12-2001 01:28
