Go to Post Only think of Gracious Professionalism as a standard to work toward personally. Never use it as a gauge to point out someone else’s shortcomings. - Rich Kressly [more]
Go Back   Chief Delphi > Technical > National Instruments LabVIEW and Data Acquisition > LabView and Data Acquisition
Unread 23-01-2006, 15:12
SHerpich SHerpich is offline
FRC #0909
SHerpich is an unknown quantity at this point
Labview keeps freezing
After taking a couple of pictures, the progress bar keeps running over and over again, but the new picture will not load and the buttons lock up. If we restart labview or restart the computer we can take a couple more pictures, but then it locks up again. Turning the camera off and on doesn't seem to help. There was no problem with the installation. We are not getting any of the errors that have been posted in the forum. The TTL adaptor is connected to the camera by a PWM cable but it is not attached to the RC. We configured the com port to the specifications in the camera manual. Does anyone know what we might have done wrong?
Unread 23-01-2006, 15:50
Mike Bortfeldt Mike Bortfeldt is offline
FRC #1126 (& 1511)
Mike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud of
Re: Labview keeps freezing
SHerpich,
We've observed the same problem. When we first installed LabVIEW, we were able to grab frames without any problems. The last time we tried, we saw the same problem you described. We would always be able to grab at least 1 frame, and sometimes several, but then the progress bar would indicate a frame grab in progress and once it would get to the end, there was a pause (several seconds), no new frame displayed, but the progress bar would start over as if it was acquiring another frame. Our workaround is to upload the camera parameters in between every frame grab (even if nothing has changed). I'm not sure why that works or if that will work for you, but give it a try.
You also may get a better response if you put this question in the LabVIEW forum.
Mike
Unread 24-01-2006, 08:59
Danny Diaz's Avatar
Danny Diaz Danny Diaz is offline
Smooth Operator
AKA: FrankenMentor
None #0418
Danny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond repute
Send a message via AIM to Danny Diaz
Sounds like a classic problem of the backup battery being too low - we've seen issues just like this that have been solved by replacing with a FRESH battery. Obviously if your CMUCam2 is able to talk to LabVIEW then you don't have a traditional "communication problem", but your battery doesn't seem to have enough juice to sustain the communications (or there's an intermediate short, very likely with PWM cables from IFI - several our PWM cables were bad). If you do something in-between grabbing frames, it would appear to me that would give the battery a [small] chance to recover.
-Danny
Danny Diaz
Former Lead Technical Mentor, FRC 418
Last edited by Danny Diaz : 24-01-2006 at 09:00. Reason: Slight over embellishment
Unread 25-01-2006, 13:33
heydowns's Avatar
heydowns heydowns is offline
AKA: Jeff Downs
FRC #1511 (Rolling Thunder)
heydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond repute
-Danny
Our team also continually sees the problem that the original poster is talking about.
We have used two different backup batteries, both fully charged. The problem was still observed.
Note that when I say "continually", I mean that we consistently get the problem on an inconsistent basis. Sometimes we get it immediately at the start of the work session and it lasts through several restarts of LabView and RC/Camera power cyclings. Other times, things work for a little while (we can grab 2-3 frames), but then we get the OP's problem of LabView not responding to input, not getting the frame that was asked for, and the frame grab progress bar continually filling up and starting over. This persists until we restart the LabView CMUCam GUI application. After restarting, it might or might not occur again immediately. It is consistently inconsistent as to when it works.
If it is really thought to be a power supply issue, then I will try to make an effort to rig up a non-battery supply and run the camera off that. Maybe the OP or someone else having the same problem can do the same (just use any standard DC power supply that fits the specs outlined in the CMU Cam docs).
Hope this helps to diagnose the problem.
Unread 25-01-2006, 14:28
Danny Diaz's Avatar
Smooth Operator
AKA: FrankenMentor
None #0418
Just curious, when you have this problem are you using a USB-to-Serial converter or a built-in serial port? We've been up and down this problem trying to reproduce it, and we're having a bugger doing anything close to what you're describing - we're using a built-in port on a desktop, though.
-Danny
Danny Diaz
Unread 25-01-2006, 20:09
Peter H Peter H is offline
FRC #1606 (Dragons)
Peter H is an unknown quantity at this point
-Danny
I have this problem with a built-in serial port on a laptop. I run the camera from a 7.2 v battery and monitor the battery voltage; the voltage does not change during operation. If the current draw were too high, the voltage would drop. 7 v should be OK, since the camera has a 5 v regulator on board.
For details, see http://www.chiefdelphi.com/forums/sh...ad.php?t=42631
Unread 26-01-2006, 01:38
Joe Hershberger Joe Hershberger is offline
AKA: jhersh
FRC #2468 (Appreciate)
Joe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to all
Please try the test release version from 2006.01.25 here and let me know what your results are. Hopefully there will be some different behavior that will help narrow down the problem.
Thanks!
-Joe
Unread 26-01-2006, 17:57
FRC #1606 (Dragons)
Thanks!
-Joe
I downloaded this new GUI, but could not get it to work. I could not find how to grab a frame.
I tried the previous GUI again; this time, it loaded 3 frames before dying. I suspect that one side or the other loses the serial channel intermittently.
Unread 26-01-2006, 18:14
holdenga holdenga is offline
FRC #1436
holdenga is an unknown quantity at this point
I've had the same issues with Labview. I've used different batteries as well as a 12v regulated/filtered supply. All versions of the software have behaved in the same fashion.
Unread 26-01-2006, 19:05
FRC #1436
UPDATE. By using the latest update posted by Joe, I was able to get through a sucessful calibration session with the camera. It still posted some "unable to communicate...check serial port..." messages a few times, but I just closed the window and kept working, ignoring the error. The camera still responded after doing this.
One new oddity came up while doing this. The pan function seemed to be reversed. It wanted to track AWAY from the light source. Tilt worked properly. Since this can be addressed in the rc code, I simply unplugged the servos in order to complete calibration.
Thanks Joe.
glenn
Unread 26-01-2006, 19:18
AKA: jhersh
Peter,
Are you saying that the new version does nothing? I really don't understand what you mean when saying
You click the grab frame button.
When you say "previous GUI", are you referring to the Java GUI from last year or are you referring to one of the previous LabVIEW releases?
Have you checked your change on the backup battery and all the wires for breaks or loose ends?
-Joe
Unread 26-01-2006, 19:19
AKA: jhersh
Thanks Joe.
glenn
The panning issue has nothing to do with the GUI... There is a jumper on the camera for each axis to reverse them.
When you get the error message does it grab part of a frame?
-Joe
Unread 26-01-2006, 21:08
FRC #1606 (Dragons)
Peter,
Are you saying that the new version does nothing? I really don't understand what you mean when saying You click the grab frame button.
-Joe
Ignore my complaint. I messed up the installation. Will try again.
Unread 27-01-2006, 08:22
For us, the 1/25 version eliminated the run-away progress bar behavior that version 1/17 exhibited.
Peter H came over to play last night and we were able to grab frames repeatedly from his camera, but with my laptop.
Unread 27-01-2006, 10:36
FRC #1436
I'll check the jumpers. Thanks.
-Joe
Yes.
glenn
Example LabVIEW Apps - Dashboard, CMUcam2 and Motors Russ Beavis National Instruments LabVIEW and Data Acquisition 9 21-01-2007 17:19
LabVIEW Com Port Error 354.FIRST LabView and Data Acquisition 4 18-01-2006 18:43
National Instruments LabVIEW and Data Acquisition Forum Danny Diaz National Instruments LabVIEW and Data Acquisition 1 16-01-2006 13:20
COM port settings for CMUcam labview testing and programming pwilczynski Programming 1 15-01-2006 15:09
National Instruments LabVIEW & Data Aquisition Forums Brandon Martus Announcements 0 22-11-2005 21:12
