Go to Post The moral of this story: A healthy respect for the customer, dedication to your job, and a positive outlook can make even the most trivial and monotonous job into a wonderful experience. - Molten [more]
Unread 23-01-2006, 13:56
Ami Schwartz Ami Schwartz is offline
FRC #1657
Ami Schwartz is an unknown quantity at this point
Exclamation G.T.S ..... (problem)
While one of my team mates was running a try out on G.T.S he thought there is somthing wrong with the way it worked :
He hooked it up and while it worked he didn't receive output from the sensor to the "IFI Loader" ( the only thing he got was the number " 0 " )
**Even when the sensor was not connected it got " 0 " or "256".
So, my question is if some one can please tell me if it's ok that i didn't receive any outpot from the Sensor.
P.S > It was connected my a digital IN/OUT on the RC .
Thx. Hamosad team # 1657
Unread 23-01-2006, 14:06
Re: G.T.S ..... (problem)
I assume you're referring to the Gear Tooth Sensor. It sounds like you're having two conceptual difficulties with printing its value.
First, its output is a very short high-going pulse whenever a gear tooth passes the sensor. It's on the order of 40-80 microseconds long. Unless you get extremely lucky, your code is not very likely to read anything other than a 0.
Second, it sounds like you might be trying to use printf with a char. For a couple of technical reasons, that doesn't work exactly the way you want it to. You'll need to cast the value to an int like this:
  char value = 1;
  printf ( "value = %d\r", (int)value );
The proper way to read the gear tooth sensor is to have it create an interrupt whenever it emits a pulse, and to use the interrupt service routine to count the pulses.
Unread 24-01-2006, 09:17
FRC #1657
Thx, but we think we know the problem.
we think that the sensor got short" .
Unread 28-01-2006, 17:01
Raym Raym is offline
FRC #1138
Raym is on a distinguished road
  char value = 1;
the GTS code returns a LONG int.
Good Luck.
Need a realistic Statics Problem sanddrag Technical Discussion 10 05-12-2005 15:07
Problem w/Mesh Kevin Thorp 3D Animation and Competition 4 17-02-2005 23:04
Programming Problem: Extremely Frustrating chantilly_team Programming 19 12-02-2005 23:00
The problem with scouting... archiver 2001 10 23-06-2002 23:49
Major problem with chipphua motors aka Scott White Motors 18 19-03-2002 19:44
