Go to Post Data is never ugly. It is only how you use it that can be. - Ed Law [more]
Unread 18-01-2006, 21:00
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
Powering the cam without a backup battery
We have noticed that the backup battery used to power the CMUcam is not very reliable, and dies out very quickly with our camera.
so we were wondering, is it possible to power the camera off of the Circuit Breaker Panel? that would be really usefull in this phase of developing, as we need the camera for the entire 4-8 hours we are here, and the main battery lasts that long (because all it is really powering is the RC).
verification?
(i ask becaus i dont want to fry the team's camera....)
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Unread 18-01-2006, 21:09
Re: Powering the cam without a backup battery
If your robot is still in bench-test mode, why not buy a little AC power supply and hook it up? That's what we did. You can buy a multiple-voltage model from Radio Shack for less than $20.
Unread 18-01-2006, 21:58
Uberbots's Avatar
Mad Programmer
AKA: Billy Sisson
ah thanks.
strange thing is that we were planning to make a tranformer0thingy to bridge between the cam and the breakers.
yah i guess that would be a good alternative.
thanks
RPI 2012
BREAKAWAY
Unread 18-01-2006, 22:14
devicenull devicenull is offline
Robot? We need a robot?
Rookie Year: 1234
devicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nice
I seem to remember that last year I plugged it into an anlog input, which is +5v, and it worked fine. I haven't tried it this year, but it might work. The +5v comes from the main battery, rather then the backup.. you would still need the backup for the servo's though
Unread 19-01-2006, 19:53
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
you definately need the backup batery or some 7.2 volt source connected to the RC for the camera to work those are really the only 2 options
KK4KQO
http://voltair.us
Unread 19-01-2006, 22:09
Denz's Avatar
Denz Denz is offline
FRC #0772 (Sabre Bytes Robotics)
Denz is on a distinguished road
Send a message via MSN to Denz
My camera worked fine in LabVIEW by just using the 5v analog.
Unread 19-01-2006, 22:53
Jared Russell's Avatar
Taking a year (mostly) off
Hook a PWM cable from the camera power supply to an analog input.
That gives you 5VDC from the main battery.
Unread 20-01-2006, 03:44
Joe Hershberger Joe Hershberger is offline
National Instruments
AKA: jhersh
FRC #2468 (Appreciate)
Joe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to all
Originally Posted by Uberbots
ah thanks.
thanks
Remember that transformers will only work with AC, not DC.
Cheers!
-Joe
Unread 23-01-2006, 21:59
Chriszuma's Avatar
Chriszuma Chriszuma is offline
Jack of all trades
AKA: Chris Hammond
FRC #0068 (Truck Town Thunder)
Chriszuma is just really niceChriszuma is just really niceChriszuma is just really niceChriszuma is just really nice
Send a message via AIM to Chriszuma
Theoretically, it should be possible to build a sort of voltage regulator that will plug into the breaker panel, and output a constant 7.2 volts, which you could plug into the backup battery jack on the RC. It would completely defeat the purpose of the backup battery, but for testing it would be much more convenient. Only problem is that I haven't seen a 7.2v voltage regulator, but you might be able to get away with an 8-volt one and possibly a resistor or two.
2006 T3 World Tour: Great Lakes - Waterloo - Palmetto - IRI
2006 Awards: Motorola Quality - RadioShack Innovation in Control
My website: http://zuma.phire.org/
Truck Town Thunder's website: http://trucktownthunder.com/
Unread 23-01-2006, 23:05
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
Just use a LM317. It would be a good idea to use a diode-type splitter and tap power from the main battery and the backup battery, whichever is stronger.
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 24-01-2006, 10:10
mogunus mogunus is offline
AKA: Luciano DiFalcone
FRC #1350 (Rambots)
mogunus is an unknown quantity at this point
Our team had this issue too. On the normal (not-FIRST) cmucam2 board, there are actually two +5v power inputs, one for the servos and one for the camera board itself. There's also a jumper to set the servos to use external power, ie the second +5v input specifically for servos. I'm fairly sure that the first version of the board also has that jumper, but I can't find the pins to hook the extra +5v for external servo power.
The servos work fine with only 5v in the normal power slot, but a little slower. (Our team connects the camera to digital in/out). I think the trade-off is worth it, though. For no irregular performance and no chance of draining the backup battery, you just take a bit of a hit in servo speed. This afternoon when I get to robotics though, I'm going to be poking around the FIRST cmucam2 to try and find where they moved the external servo power jumpers. If I find them, I'll post here. That'd give us best of both worlds: assured battery life, and max servo speed.
... one of the main causes of the fall of the Roman Empire was that, lacking zero, they had no way to indicate successful termination of their C programs.
-- Robert Firth
Unread 27-01-2006, 10:00
ldeffenb ldeffenb is offline
AKA: Lynn Deffenbaugh (Mr)
None #0386 (Team Voltage 386)
ldeffenb has a spectacular aura aboutldeffenb has a spectacular aura aboutldeffenb has a spectacular aura about
Send a message via ICQ to ldeffenb Send a message via AIM to ldeffenb Send a message via Yahoo to ldeffenb
Check out http://www.ifirobotics.com/docs/firs...up-charger.pdf
An online charger/supply circuit for the RC backup battery and hence all servos and the camera!
Lynn (D) - Team Voltage 386 Software
Dump Backup Battery Kingofl337 Electrical 17 24-12-2005 13:44
Backup battery will not power RC steven114 Control System 13 24-01-2005 01:59
Urgent!!! Problem concerning Backup battery and autonomous. Code\\Pilot Programming 3 26-02-2004 16:44
Cutting wire on backup battery MikeDubreuil Electrical 4 23-02-2004 18:55
Weight of Backup Battery? sanddrag Control System 0 16-02-2004 20:58
