Make all command
Hy all,
Me again.. I've got the Borland compiler up and ready ( did the hello World thingy ) ![]() I have a couple of files that need to be put together some how by the "make all" command. But when i use that in the directory with the files that need to be together it gives the following: C:\code>make MAKE Version 5.2 Copyright (c) 1987, 2000 Borland gcc -O -g ticker.o score.o update.o core_sql.o helper.o battle.o cleanup .o logging.o -o ticker -lmysqlclient -lcrypt -lz gcc wordt niet herkend als een interne of externe opdracht, programma of batchbestand. ** error 1 ** deleting ticker Does anyone know why this goes wrong ? it says gcc is not recognized as an intern or external program or batchfile... pls help Greetzz pMzQ, |
Re: Make all command
I'm slightly confused as to why it says bcc (I believe that the Borland compiler is called bcc), but regardless, ensure that the path to the Borland bin directory is in your PATH environment variable.
Typically the compiler installs to C:\Borland\bin, I think. Been a while since I used it. |
| using eclipse | dasRatsel | Programming | 82 | 02-01-2006 13:20 |
| How do teams normally make travel arrangements? | slickguy2007 | General Forum | 8 | 06-12-2004 20:22 |
| Could you make me some Mac floppies? | sanddrag | IT / Communications | 1 | 12-09-2004 22:53 |
| Anyone ever make something rideable (go-kart/scooter/misc.) from the Kit Of Parts? | Elgin Clock | Technical Discussion | 9 | 29-07-2004 22:09 |
| Run command... frightening | archiver | 2001 | 1 | 24-06-2002 03:37 |
