Go to Post I pumped my fist to cheer - but since I was a ref at the time it looked like I signaled a red foul... - Tom Ore [more]
Unread 24-01-2006, 11:17
cprogrammer's Avatar
cprogrammer cprogrammer is offline
FRC #1595 (Gremlins)
cprogrammer will become famous soon enoughcprogrammer will become famous soon enough
Gear Tooth Sensor Trouble
I have a question on the G.T.S. when we try to get a read out on the screen all we get is a value of zero. Is teh GTS defined as an rc_dig_inxx or is it a rc_dig_outxx. Another thing the J1 pins are connected to the 12V circut breaker and J2 goes to the Dig in/outputs. Also can anybody tell me the way that they mounted their gyro. If anybody could answer even one of these questions that would be very helpful.
Unread 24-01-2006, 13:48
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Re: Gear Tooth Sensor Trouble
The Gear Tooth Sensor emits a pulse whenever a tooth passes it, varying in length vased on the direction, however our controller isn't very capable of decoding the direction while remaining stable and functional But you can measure the counts by setting up an interrupt to fire on each pulse, then incrementing a counter, take a look at Kevin Watson's interrupt and encoder code at http://kevin.org/frc/
Also, it goes in a digital input, 1 to 6 for interrupts.
Matt Krass
Will the gear tooth break? sanddrag Technical Discussion 11 23-01-2006 14:24
Gear Tooth Sensor AMIRAM Electrical 2 22-01-2006 04:09
Gear tooth sensor vs. Optical Encoders Avarik Programming 7 17-01-2006 10:18
Accelerometer vs Gear Tooth Sensors zdeswarte Electrical 4 22-01-2005 15:35
gears Michael Leicht Inventor 12 16-09-2004 10:52
