Go to Post your chain routing is cute - rachal [more]
Unread 24-01-2006, 09:44
ducttapehaxor ducttapehaxor is offline
AKA: Seth Lieblich
FRC #1712 (Dawgma)
ducttapehaxor has a spectacular aura aboutducttapehaxor has a spectacular aura about
Help! unable to locate 'p18cxxx.h'
Recently I downloaded Kevin Watson's Gyro code, without changing any thing on it (mplab 7.20 running on windows xp) when I tried to compile it I got an error of unable to locate 'p18cxxx.h'. However in other projects using the default code (from ifi) I looked and found the #include <pc18cxxx.h> and then compiled them successfully (I also wrote some code for driving which also worked). I have tried downloading another version of the gyro code from www.kevin.org/frc without any change in the error. Any Ideas?
Unread 24-01-2006, 16:13
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: Help! unable to locate 'p18cxxx.h'
In the project build properties, make sure all the paths are correct.
Error: Unable to locate 'stdio.h' phrontist Programming 4 09-02-2005 19:59
PLEASE help me locate pictures from Buckeye ... Stu Bloom Regional Competitions 17 10-05-2004 09:20
Error message in MPLAB IDE dddriveman Programming 11 18-03-2004 06:34
Unable to transfer Document in Streamline squide 3D Animation and Competition 12 16-02-2004 23:40
Where can we locate another Double Solenoid? David Hoff Pneumatics 1 03-02-2004 00:13
