Go to Post ...there's nothing worse than a problem you can't solve because you don't even know about it. - Dave Flowerday [more]
Unread 24-01-2006, 13:03
pmzq pmzq is offline
pmzq is an unknown quantity at this point
Make all command
Hy all,
Me again..
I've got the Borland compiler up and ready ( did the hello World thingy )
I have a couple of files that need to be put together some how by the "make all" command.
But when i use that in the directory with the files that need to be together it gives the following:
C:\code>make
MAKE Version 5.2 Copyright (c) 1987, 2000 Borland
gcc -O -g ticker.o score.o update.o core_sql.o helper.o battle.o cleanup
.o logging.o -o ticker -lmysqlclient -lcrypt -lz
gcc wordt niet herkend als een interne
of externe opdracht, programma of batchbestand.
** error 1 ** deleting ticker
Does anyone know why this goes wrong ?
it says gcc is not recognized as an intern or external program or batchfile...
pls help
Greetzz pMzQ,
Unread 24-01-2006, 13:15
Brandon Martus's Avatar Unsung FIRST Hero
Brandon Martus Brandon Martus is offline
busy.
AKA: B. Slash Kamen
Brandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond repute
Send a message via ICQ to Brandon Martus Send a message via AIM to Brandon Martus Send a message via Yahoo to Brandon Martus
Re: Make all command
FYI: http://www.chiefdelphi.com/forums/sh...ad.php?t=29944
Brandon Martus
e-mail
phrontist's Avatar
phrontist phrontist is offline
Proto-Engineer
AKA: Bjorn Westergard
FRC #1418 (Vae Victus)
phrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond repute
Send a message via AIM to phrontist
Originally Posted by pmzq
Hy all,
Me again..
C:\code>make
pls help
Greetzz pMzQ,
Groetjes uit America! Dit is niet echt en forum voor C, maar voor en robot competitie, FIRST.
University of Kentucky - Radio Free Lexington
"I would rather have a really big success or a really spectacular crash and failure then live out the warm eventual death of mediocrity" - Dean Kamen
Unread 24-01-2006, 16:16
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
I'm slightly confused as to why it says bcc (I believe that the Borland compiler is called bcc), but regardless, ensure that the path to the Borland bin directory is in your PATH environment variable.
Typically the compiler installs to C:\Borland\bin, I think. Been a while since I used it.
using eclipse dasRatsel Programming 82 02-01-2006 13:20
How do teams normally make travel arrangements? slickguy2007 General Forum 8 06-12-2004 20:22
Could you make me some Mac floppies? sanddrag IT / Communications 1 12-09-2004 22:53
Anyone ever make something rideable (go-kart/scooter/misc.) from the Kit Of Parts? Elgin Clock Technical Discussion 9 29-07-2004 22:09
Run command... frightening archiver 2001 1 24-06-2002 03:37
