Go to Post The code won't compile if you violate the rules of the programming language...but English is more robust, it seems to work pretty well no matter how we engineering nerds mangle it! - MrForbes [more]
  #76   Spotlight this post!
Unread 24-01-2006, 16:28
MrBamboo MrBamboo is offline
Lead Designer of #1888 (Plano West)
AKA: Fei
FRC #1888 (Sigma F)
MrBamboo is an unknown quantity at this point
Re: What is the hardest (yet possible) task in this year's game?
Originally Posted by yodameister
How about one bot collecting and holding all 80 balls on the playing field? That would be quite interesting to see.
The problem with that is since any ball you score is up to the opponent to put back into the field, the only real feasible way to achieve that is you don't score any points after autonomous mode. And by the time you have all the balls, probably around the last quarter if ever, they will just put all three of their robots defending your one robot that has balls, making it impossible to score those 80 balls, which most likely means you lose
  #77   Spotlight this post!
Unread 24-01-2006, 16:34
As the weeks go by and the physics of the game sinks in, I think the real magic trick is going to be finding a way to guard or block the center goal, parked infront of it (not chasing robots around to block their shots).
I notice the rules say you cannot extend in a 'stable configuration' above a certain height - does that mean you could take swipes at a ball in flight, if your flailing arms are not 'stable' ?
Could you have a bot with a big sticky tongue that shoots out and snatches balls out of the air, like flys?
<G16>
Maximum Height
- A ROBOT may not extend above 60” above the floor or the ALLIANCE PLATFORM in a stable configuration at any time during a match...
  #78   Spotlight this post!
Unread 24-01-2006, 16:38
AKA: Fei
FRC #1888 (Sigma F)
I notice the rules say you cannot extend in a 'stable manner' above a certain height - does that mean you could take swipes at a ball in flight, if your flayling arms are not intristically 'stable' ?
I think the rule means that its ok if you exceed the height limit if an accident happens and your robot flips over and the diagonals goes over 5 feet.
Other wise the height rule pretty much says you cannot block the goal or other robot's firing mechanism. Well unless their shooter is not placed at the max height, which I doubt since that would make their shooter very easily blocked.
The closest thing I've heard about interfering with a shooter other than just plain collision of robots is using pneumatics to blow air in front of opponent shooters to offset the flight path of the launched ball. However I'm not entirely sure this is legal so you probably should check on that. Also since you have to take time to recompress air it will not be consistant.
  #79   Spotlight this post!
Unread 24-01-2006, 16:45
MattB703 MattB703 is offline
AKA: Matt
None #0703 (Team Pheonix)
MattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud of
Don't forget that the hypothetical robot holding all 80 balls has 2 partner robots to help "move" the opposing robots out of the way. Certainly you have a valid point, but I do believe that hording and scoring late is going to be a powerful strategy.
  #80   Spotlight this post!
Unread 24-01-2006, 17:08
Originally Posted by Evilfrog87
In my opinion, it is impossible to score 10 balls in 10 sec. For a ball to be scored, it must exit the chute: "<G05> In order for a ball to score, it must enter the goal and exit via the exit chute..." this takes anywhere between 1 and 3 sec. (with multiple balls).
This leaves you with 7 seconds to shoot all of the balls (7/10ths of a sec. per ball). To shoot more than one ball per second using a CIM to drive two 8" wheels a few thousand rpm a flywheel is required. To bring your shooter up to speed it takes around 3 seconds.
The final total is 4-6 seconds to shoot 10 balls (2/5-3/5ths of a sec. per ball). Anyone who can shoot and score all 10 balls in 4 seconds autonomously deserves more than an award.
Impossible, eh? Too long to spin up? Well then, I'll make a 2 Big CIM/2 Little CIM/2 FP/Van Door/Globe/Window Motor Shooter that can spin up in .1 seconds and shoot 60 balls per second!
I guess the point I'm trying to make is nothing is impossible. Its just.. some thing are very hard.
  #81   Spotlight this post!
Unread 09-02-2006, 15:24
bluisnake's Avatar
bluisnake bluisnake is offline
Bluisnake
AKA: Robert Flanagan
FRC #1390 (welethedawgsout)
bluisnake is on a distinguished road
Lightbulb Re: What is the hardest (yet possible) task in this year's game?
Get most points in both center and corner goals. don't think anyone can multitask that much
Robert Flanagan
Programmer, Team #1390
St. Cloud, Fl.
Part of winning alliance at The Mayhem at The Museum competition, Fort Lauderdale, Fl.
Everywhere and nowhere, like the wind
  #82   Spotlight this post!
Unread 09-02-2006, 16:22
Chief Samwize Chief Samwize is offline
AKA: Sam
FRC #0051 (Wings of Fire)
Chief Samwize has much to be proud ofChief Samwize has much to be proud ofChief Samwize has much to be proud ofChief Samwize has much to be proud ofChief Samwize has much to be proud ofChief Samwize has much to be proud ofChief Samwize has much to be proud ofChief Samwize has much to be proud ofChief Samwize has much to be proud of
How about scoring five out of ten balls in the center goal from the starting position during autonomous
  #83   Spotlight this post!
Unread 09-02-2006, 16:48
Sachiel7's Avatar
Sachiel7 Sachiel7 is offline
<Yes I managed to flip it
AKA: Shayne Helms
FRC #1132 (RAPTAR Robotics)
Sachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really nice
Send a message via AIM to Sachiel7
What about scoring all 10? I think its possible, yet difficult...for some....
-=Sachiel7=-
There's no such thing as being too simple!
Look for Team #1132, RAPTAR Robotics at the VCU Regional this year!
  #84   Spotlight this post!
Unread 09-02-2006, 19:39
vadyr's Avatar
vadyr vadyr is offline
103 Alumni/Mentor - FIRST Volunteer
AKA: Bobby
no team (Cybersonics (Mentor))
vadyr is a jewel in the roughvadyr is a jewel in the roughvadyr is a jewel in the rough
Send a message via AIM to vadyr
how about shooting while moving?
www.cybersonics.org
  #85   Spotlight this post!
Unread 09-02-2006, 20:21
Sachiel7's Avatar
AKA: Shayne Helms
Ah that's fairly simple
-=Sachiel7=-
  #86   Spotlight this post!
Unread 09-02-2006, 20:24
vadyr's Avatar
AKA: Bobby
well yea we can do it...but i mean shooting all 10 balls in autonomous while moving and getting atleast most of them in
www.cybersonics.org
  #87   Spotlight this post!
Unread 09-02-2006, 20:27
Sachiel7's Avatar
AKA: Shayne Helms
Definitially a trick
-=Sachiel7=-
  #88   Spotlight this post!
Unread 09-02-2006, 21:48
blaskay16's Avatar
blaskay16 blaskay16 is offline
President/Driver
AKA: Jeremy
FRC #0815 (Advanced Power)
blaskay16 is infamous around these partsblaskay16 is infamous around these partsblaskay16 is infamous around these partsblaskay16 is infamous around these parts
Send a message via AIM to blaskay16 Send a message via Yahoo to blaskay16
I think the autonomous is the hardest part of this years competition because of the alloted time. its only 10 second. fortunately at team 815 we have 15 different autonomous codes
  #89   Spotlight this post!
Unread 16-01-2008, 18:30
Branden Ghena's Avatar
Branden Ghena Branden Ghena is offline
Previously: tawnos23
FRC #0240 (TEMPEST)
Branden Ghena has a spectacular aura aboutBranden Ghena has a spectacular aura aboutBranden Ghena has a spectacular aura about
this seems slightly pointless
Infared in Next Year's Game Paradox1350 Rumor Mill 45 02-04-2004 20:45
The key to this year's game (long) archiver 2001 6 23-06-2002 23:05
do you like this years game archiver 2001 8 23-06-2002 22:29
Next Years Game Ben Rumor Mill 24 01-08-2001 09:04
How was this years game compared to others? Anthony S. General Forum 7 13-06-2001 15:43
