Go to Post A well-designed shifting transmission, controlled by an experienced driver (or a clever bit of software), is an advantage. - Alan Anderson [more]
Unread 24-01-2006, 17:08
Tim Delles's Avatar
Tim Delles Tim Delles is offline
Since 2001.
FRC #0078
Tim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond repute
Re: Ramp Scoring, At 00:00 or After?
Why not simply turn your robot so that it's at an angle or even facing sideways on the ramp? Assuming you're not using wheels that swivel, it should work and be easier to implement than brakes.
Because that takes time, little fo which should be exerted on getting onto the ramp if you decide to do it. the less time you take on the ramp the more time you have to score.
Timothy Delles - Clarkson University
2011 - Present: FRC Team 78 - AIR Strike
2011 - Present: VEX Team 78 - AIR Strike
2010 - 2011: FRC Team 3280 - Rhode Rebels
2001 - 2009: FRC Team 229 - Division By Zero
Unread 24-01-2006, 19:29
occra 23.
AKA: ryo
None #1481
so wait. if a robot is running full speed towards the ramp, and right before the buzzer it shifts to neutral, and a couple seconds (within 10) after the buzzer it rolls onto and stays on the ramp. is that going to be scored? there are ways to mechanically store energy until the power is cut and then it has a way to move the robot onto the ramp and keep it there... is that going to be allowed?
Unread 24-01-2006, 20:16
Historically, it would be scored. The only ways I can think of to store energy after the match (pneumatics and springs) would neither have the power nor the range to get a robot onto the ramp. Lock it in place, yes, but get it on, no.
Unread 24-01-2006, 21:09
Tim Delles's Avatar
Since 2001.
FRC #0078
Basically look at it this way.
If you are not on the ramp at the end, there is almost no chance you are going to be able to get your robot completely on the ramp. There is a lot of physics involved with this, but im assuming that you would have to be going at a very uncontrollable and unatainable speed to be able to coast onto the ramp after power was shut off. However if teams would like to give it a try go for it and tell me how it turns out.
Unread 24-01-2006, 22:48
There have been bots over the years that had mechanisms that were triggered at the end of the match, or when the power to the controllers is removed, and they moved in a way to score points after the buzzer.
Very impressive if you can pull it off. One that comes to mind is the game of 1999, when the bots had to hold scoring objects 8 feet in the air to score.
a few had slow moving spring or surgical tubing extenders that raised slowly after being released.
Total engineering elegance when it works.
Unread 05-02-2006, 13:05
Nitroxextreme's Avatar
Nitroxextreme Nitroxextreme is offline
Relation to Mrs. Steve
AKA: Jon
FRC #1626 (Falcon Robotics ; 190 (Gompei and The Herd))
Nitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to behold
Send a message via AIM to Nitroxextreme
Has this been asked in the Q & A forum because it could effect many designs...I believe
"He needed a chuck norris lesson in FIRST"...."I will give him a round house kick to the face...with gracious professionalism"
Unread 05-02-2006, 17:02
Ethulin Ethulin is offline
Too many hats to count
AKA: Erik Thulin
FRC #0492 (Titan Robotics)
Ethulin has much to be proud ofEthulin has much to be proud ofEthulin has much to be proud ofEthulin has much to be proud ofEthulin has much to be proud ofEthulin has much to be proud ofEthulin has much to be proud ofEthulin has much to be proud of
Send a message via AIM to Ethulin
I just asked, awaiting a response.
- Erik
2003 Pacific Northwest Regional Website Award || 2003 Pacific Northwest Regional Finalist || 2003 Pacific Northwest Regional Engineering Inspiration Award || 2004 Pacific Northwest Website Award || 2004 Pacific Northwest Regional Champions (#1 seed) || 2004 Galileo Semi-Finalist || 2005 Pacific Northwest Regional General Motors Industiral Design Award || 2005 Pacific Northwest Regional Champions (#1 seed) || 2005 Galileo Finalist || 2006 Pacific Northwest Regional Chairman's
Stamp Scouting || Titan Robotics
FIRST Volunteers D. Gregory General Forum 46 10-09-2006 12:53
To ramp, or not to ramp? phrontist Rules/Strategy 27 26-01-2006 17:56
New Ideas for next year's competition XCJP General Forum 34 10-05-2005 10:07
scoring ramp dimensions archiver 2000 3 24-06-2002 00:13
hieght of the scoring ramp archiver 2000 1 24-06-2002 00:08
