Go to Post I always get a little stressed as arm operator, especially with Paul Copioli standing behind me screaming at me. - JohnnyB [more]
Unread 24-01-2006, 17:19
FRC1710's Avatar
FRC1710 FRC1710 is offline
FRC #1710
FRC1710 is an unknown quantity at this point
Sprocket
Can we tap and die the sproket on the out drive shaft so as to hold the sproket in place?
Unread 24-01-2006, 17:24
Jason Kixmiller's Avatar
Jason Kixmiller Jason Kixmiller is offline
IWIWAB
FRC #1747 (Harrison Boiler Robotics)
Jason Kixmiller is a splendid one to beholdJason Kixmiller is a splendid one to beholdJason Kixmiller is a splendid one to beholdJason Kixmiller is a splendid one to beholdJason Kixmiller is a splendid one to beholdJason Kixmiller is a splendid one to beholdJason Kixmiller is a splendid one to beholdJason Kixmiller is a splendid one to behold
Send a message via AIM to Jason Kixmiller
Re: Sprocket
A lot depends on your set up, however, I would try to find another method (welding, cutting a key, pinning...). One of the most probable problems would be the sprocket "unscrewing" itself from the shaft depending on the direction of rotation.
Unread 24-01-2006, 17:41
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Re: Sprocket
It seems as if you may have intended for this question to go in the official FIRST Question & Answers forum.
That can be found here: http://forums.usfirst.org/forumdisplay.php?f=52
Please be aware that any answers you find here are unofficial and may be incorrect or inconsistent with how FIRST interprets your question and the rules.
--Madison--
...down at the Ozdust!
Unread 24-01-2006, 17:50
EOC's Avatar
EOC EOC is offline
AKA: Eric Curry
None #1208 (Metool Brigade)
EOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant future
Re: Sprocket
Sounds iffy to me, why not try set screws?
Unread 25-01-2006, 02:49
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
Re: Sprocket
To Quote Woodie Flowers "Setscrews inhale audibly."
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 25-01-2006, 03:08
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Sprocket
Can you legally? Yes. Should you? Maybe not. Using threads is not the best way to transmit torque. At the least, you would also need a left-handed threaded hole int he end of the shaft in which you place a retaining bolt and washer, like how a drill chuck is held on.
Vex Robotics Sprocket and Chain Kit Morenoh149 FIRST Tech Challenge 3 08-01-2006 22:39
Stuck sprocket - need advice sanddrag Technical Discussion 20 13-10-2005 12:12
Need to find 5/8" sprocket hedgehogger Kit & Additional Hardware 3 14-02-2004 09:23
chain ridding up and off sprocket problem... davidhoare Technical Discussion 4 04-02-2004 10:13
If set screws suck . . . Madison Technical Discussion 17 22-12-2003 19:19
