Go to Post At every event I've seen this year, there has been at least one robot that left a part on the field. Even some of the robots have decided they don't want to play and this year and made a break for it in autonomous! :yikes: - ctt956 [more]
Unread 24-01-2006, 18:11
Erics626's Avatar
Erics626 Erics626 is offline
Cool, Calm, Collected
None #1018 (Robodevils)
Team Role: Electrical
Erics626 is a jewel in the roughErics626 is a jewel in the roughErics626 is a jewel in the rough
Send a message via AIM to Erics626
Shifting with easyC
OK so here's my problem. Hopefully I explain to the best I can. We want to be able to shift our Dewalt transmissions attached to the CIM motors. We have a servo attached to the shifting plate of the transmission, and when the servo rotates, it shifts gear. Our default gear is second, and we have the servo set up so it is second gear at 127. We want the trigger button to up shift, and the thumb button to downshift. Our problem is that the transmission only switches gear when the trigger or thumb button are depressed. We want it so that when a trigger or thumb button is hit, it shifts gear and you do not have to hold the button down. Is there anyway to fix this. Any help would be appreciated. My email address is greendblink182@hotmail.com
Championship Finalist - 2006 Buckeye Regional (Thanks 461 and 141!)
Fourth Year FIRST Member
Third Year Electrical Team Leader
First Year BEST and FIRST Robotics Team Co-Leader
Second Place - Robotics Competition, 2005 Bearcat BEST
Second Place - BEST Competition, 2005 Bearcat BEST
Most Photogenic - 2005 Bearcat BEST
Most Robust - 2005 Bearcat BEST
Fourth Place - Robotics Competion, 2005 Nationals(South's BEST)
"Get your philosophy from a bumber sticker."-Billie Joe Armstrong
Unread 24-01-2006, 18:58
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Re: Shifting with easyC
I almost always have my switches work via edges not via states.
For example rather than:
If (switch==1) then PWMout = XXX else PWMout = YYY
I do this:
If (switchNow==1 and switchOld==0) then PWMout=XXX
Elseif (switchNow==0 and switchOld==1) then PWMout=YYY
The second case allows you to have other conditions change the state of the PWMout.
If you do things this way, what you want to do becomes trivial:
If (switchNow==1 and switchOld==0 and PWMout=XXX) then PWMout=YYY
Elseif (switchNow==1 and switchOld==0 and PWMout=YYY) then PWMout= XXX
The above pseudo code will allow you to use your switch to toggle between XXX & YYY states.
There are probably better ways to do this but I hope this will give you some idea of how it can be done.
Joe J.
Team #88, TJ2
EasyC Wish List dcbrown Programming 32 14-08-2006 09:24
EasyC v2.0 is mandatory for FVC! skimoose FIRST Tech Challenge 7 14-01-2006 18:37
Kickoff easyC workshop integrated into EasyC help file Dan Larochelle Programming 0 11-01-2006 06:12
Is a shifting transmission really necessary? Jay TenBrink Technical Discussion 78 02-08-2005 09:21
