Go to Post Volunteers are in short supply and we always need more. - Koko Ed [more]
Unread 24-01-2006, 04:07
lkdjm's Avatar
lkdjm lkdjm is offline
AKA: David Mazza
FRC #0564 (Digital Impact)
lkdjm will become famous soon enough
Send a message via AIM to lkdjm Send a message via Yahoo to lkdjm
Exclamation AHHH! I'm a lost newbie! I need help!
I have been trying to get the camera to work for a few days. The only led that comes on is green, and I think it is the power one. I have gotten the camera to center itself by plugging the servos into pwm output, that's it. grrr, I feel like everyone has figured this out but me.
I need more info mainly on the TTL port. I am clueless as to how to set that up.
I know this might be a lot to ask but could someone make a quick schematic on paint of all the connections you need to get the camera to work? I have not found any good solid and simple info or diagrams in any documentation, so I think that would be REALLY HELPFUL to a lot of people!
I know that is a lot so thanks for all your help in advance!
-David Mazza
-Team 564
-564.first@gmail.com
Longwood's Digital Impact
Unread 24-01-2006, 14:14
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
Re: AHHH! I'm a lost newbie! I need help!
Hopefully this will help. Ground is always marked with a little "B" on the TTL converter and the FRC/EDU boards.
I apologize for the crudity of this model...
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 24-01-2006, 14:49
lkdjm's Avatar
AKA: David Mazza
Smile Re: AHHH! I'm a lost newbie! I need help!
Thank you soooooooooooooooooooooo much!!!
This may be a stupid question, but what what wire(s) to you use to go from the TTL converter to the TTL port on the FRC? And also, on that chip I only see three prongs to connect to the camera. How does it connect to the RC? I don't see any female connections.
Unread 24-01-2006, 15:59
viewtyjoe viewtyjoe is offline
Code Monkey
AKA: Nathaniel Davis
viewtyjoe is an unknown quantity at this point
Send a message via AIM to viewtyjoe
To connect the TTL Converter to the RC, just attach the converter to the pins on the RC. I can't think of any cable that you could use to connect from converter to RC offhand. There's a three pin female connector on the camera to the right of the serial port that you use to hook PWM cable from the camera to the TTL converter.
Unread 24-01-2006, 16:48
Look closer. The female connections are on the side of what appears to be a solid black square. The whole board stands on edge on the RC TTL pins.
Unread 24-01-2006, 18:58
Vashts6583's Avatar
Vashts6583 Vashts6583 is offline
The sleepless
AKA: Rob Metzger
FRC #0007 (Team 007)
Vashts6583 is a name known to allVashts6583 is a name known to allVashts6583 is a name known to allVashts6583 is a name known to allVashts6583 is a name known to allVashts6583 is a name known to all
Send a message via ICQ to Vashts6583 Send a message via AIM to Vashts6583 Send a message via MSN to Vashts6583 Send a message via Yahoo to Vashts6583
Question Re: AHHH! I'm a lost newbie! I need help!
Ok. off topic, but how would I be able to stop giving the camera feedback while holding down a controller button? In other words, I want the camera to stop searching/tracking while holding down a button on a joystick. How?
2005: Software Assistant
2006: Software Head
2007: President/Driver/Software Head/Temporary Safety Captain
//2005: Chesapeake Regional - Finalist
Life is what you do outside of FIRST. No wonder it's so short.
Unread 24-01-2006, 19:04
Andrew Blair's Avatar
FRC #0306 (CRT)
Somewhere, there is a disable_camera function. It's probably not called that, but there is one thta performs that duty. Simply call it when you want to disable the camera. A more complete answer should be posted soon, by someone who knows more than me.
-Sir Francis Bacon
-Albert Einstein
Unread 25-01-2006, 04:18
lkdjm's Avatar
AKA: David Mazza
Yeah, thanks, I see that now. Stupid me
Unread 28-01-2006, 08:41
Just closing out the original issue in case anyone else has had a similar problem.
It turns out the green light only problem was a result of the camera board being shorted to the aluminum gimbal plate.
They understood the camera board had to be insulated from the aluminum so they wrapped it with electrical tape before attaching the board, but they didn't have all three spacers called for in the mounting directions installed. The sharp points of solder on the back of the board poked through the electrical tape and made contact with the aluminum backing.
No permanent damage was done, everything works now.
Lost and Found sammy Championship Event 2 30-04-2005 12:59
Lost Luggage robofrog716 Championship Event 1 21-04-2004 19:14
Lost and Found at Regionals RoboCoder Regional Competitions 6 22-03-2004 02:55
2000, 2001, 2002, Videos Boesing General Forum 28 07-02-2004 00:32
