Go to Post Adam, when most of us look at your robots, we aren't thinking, "How Creative!" What we are thinking is more like, "Holy Crap!" - Richard Wallace [more]
Unread 23-01-2006, 23:17
Sachiel7's Avatar
Sachiel7 Sachiel7 is offline
<Yes I managed to flip it
AKA: Shayne Helms
FRC #1132 (RAPTAR Robotics)
Sachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really nice
Send a message via AIM to Sachiel7
Window motors....
Ok, I have a few questions related to the *new*(ish) smaller denso window motors:
-might anyone have a CAD file for the little buggers?
-has anyone else noticed that we weren't given a plug in the kit to actually power them? Or are we missing them from our kit? As of now, I havent seen anything...
-Has anyone tested them this year for backdriving? If i remember they have a spur gear in the worm drive and almost completely resist backdrive.
Thanks!
-=Sachiel7=-
There's no such thing as being too simple!
Look for Team #1132, RAPTAR Robotics at the VCU Regional this year!
Unread 23-01-2006, 23:41
ebmonon36's Avatar
ebmonon36 ebmonon36 is offline
AKA: Eric Bredehoeft
FRC #1018 (Robodevils)
ebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud of
Send a message via AIM to ebmonon36
Re: Window motors....
I have an inventor file of the motor if you would like it. PM me and I can e-mail it to you. I don't recall having a plug for them. We were using aligator clips for test purposes. They are extremely difficult to turn by hand (most likely impossible).
Eric
Unread 24-01-2006, 00:01
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Originally Posted by ebmonon36
They are extremely difficult to turn by hand.
Eric
You actually can turn them by hand? This isn't good.
Unread 24-01-2006, 00:31
Arkorobotics's Avatar
Arkorobotics Arkorobotics is offline
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
Arkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to behold
Send a message via AIM to Arkorobotics
Thanks!
If by backdriving you mean cranking it without the motor being on and moving it instead, then.. don't try. The last time I checked the worm gear was plastic, but that could be an older model. I have see the worm gear inside get striped teeth. So to be on the safe side, I wouldn't try.
Wait now I remember we made an arm with these motors, and we had to hand crank it back, but it ended up tearing up the insides. Maybe it could have been because we weren't nice to it.
2007 Rockwell Automation Innovation in Control Award winners (Southern California Regional)
Crescenta Valley High School Team 589
http://www.arkorobotics.com My Blag
3.141592653589793238462643383275902884197 <- Current memorization of Pi
Callsign: N6ARA
Unread 24-01-2006, 00:39
ebmonon36's Avatar
I havent been able to but I assumed it could be done...
ERic
Unread 24-01-2006, 08:45
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
In most automotive applications of window are not supposed to fall down as the car drives down the road. To that end, there are specs for "wind noise" which spell out how much residual torque the motors retain after the power is released as well as for "forced entry" which define how much the motors can move under various backdrive conditions.
In almost every case, automotive window motors are not intended to be backdriven. In actual fact, the motor manufacturers are walking a fine line -- there is a strong correspondence between backdrive and effeciency. If they make the motors too non-backdriveable, they make the motors less effecient, which means that they need a bigger motor and more current to lift the window -- neither of which their OEM customers like. On the other hand, if they make the motors too efficient, the windows creep down as the cars drive over rough roads, which drives the end users nuts with high pitched wind noise sounds.
The bottom line is that most automotive window motors CAN be backdriven if you torque them hard enough, but they don't like it and you will probably get into trouble eventually.
Joe J.
Team #88, TJ2
Unread 24-01-2006, 21:53
Leo 1529's Avatar
Leo 1529 Leo 1529 is offline
uber fabricata, webmasta, president
AKA: Tzu-san
FRC #1529 (Cyber-Cards)
Team Role: Webmaster
Leo 1529 has a spectacular aura aboutLeo 1529 has a spectacular aura aboutLeo 1529 has a spectacular aura about
we decided against using the window motors so we could use the Bosch motor for our robot and we were also concerned with the strippage that could occur within these motors
Unread 24-01-2006, 21:58
Andrew Blair's Avatar
FRC #0306 (CRT)
Virtually impossible. We've been using these motors (Or variations on them) for years, and never had one fail. .... Except that one time we crashed the go-cart into the pole...
-Sir Francis Bacon
-Albert Einstein
Unread 24-01-2006, 22:43
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
While performing some tests on our prototype with the new window motors, one the plastic housings cracked - Be Very careful with them!!!! They are not like the window motors of previous years.
Unread 25-01-2006, 08:12
AKA: Dr. Joe
FRC #0088 (TJ2)
It is possible to strip the internal plastic gear but not easy.
We discovered this in 1999 when a failure cost us an easy win and eliminated us from the tournament at the Championships at EPCOT.
Do not run these motors into a brick wall at high speed.
We had an arm that lifted us off the ground. The arm used an "over center" linkage to lock our arm in place. What would happen is every time we lifted, the motor would drive this overcenter arm into a stop. We made no effort to slow the arm down, we just ran it into the stop. After a season of lifting perfectly, the motor developed a hard spot where the gear teeth were bent from repeated bashings. In our last match of the season, the robot just would not lift off the ground. Root cause analysis showed that the plastic gear was the problem. Note that a window motor would not have failed in this way because window motors are designed to be run into a brick wall at full speed -- they have an internal rubber coupling that prevents the full shock load from going into the plastic worm gear.
Bottom line... ...don't run power sliding door motors into a hard stop at high speed.
Note: for a conveyor application I doubt you will have to worry at all.
Joe J.
Team #88, TJ2
Unread 25-01-2006, 09:58
Gdeaver Gdeaver is offline
FRC #1640
In past years window motors, we have noticed a increase in backlash after hard use. They never failed but, then we never abused them. Our designs allowed for something else to slip instead of locking up the motor.
Unread 25-02-2006, 12:33
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
Eric
Just file away the white plastic connector housing and use normal fast-on connectors (terminal fully covered variety). They are a little too wide but work fine if you run the tab up the outside edge of the fast-on.
Unread 25-02-2006, 12:35
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
Eric
They should not turn by hand. One of the properties of a worm gear arrangement is that it will hold its position, kinda nice feature for a WINDOW motor, heh?
Complete Drill, Seat, and Window motors for trade archiver 2000 0 23-06-2002 22:16
