Go to Post Who cares about having a boyfriend when I have my robot? - Jaine Perotti [more]
Unread 24-01-2006, 19:48
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
The chasing-lights RC error
Every now and then when I press the "Program" button on the RC, it responds with a red-light chaser, all green on / all red on and then a green-light chaser. Meanwhile, the team color LED blinks red - blue - blue.
What does this (overly-complex ) error code mean and what causes it?
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 24-01-2006, 20:06
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
Re: The chasing-lights RC error
We had this trouble occasionally when we had a flaky serial cable. The solution we used is twofold:
First, you have to instruct the master microprocessor not to boot the user one. Hold both the RESET and PROG buttons on the RC for about five seconds. Release the RESET button, wait another five seconds, and then release the PROG button. The Battery light should go green, the Program light should go orange, and the rest should stay unlit.
Then, use a known good serial cable (make sure it doesn't have excessive length! Use only one 6' cable if possible) to download your code. Should fix it right away.
Shift to the left, shift to the right!
Pop up, push down, byte, byte, byte!
Unread 24-01-2006, 23:27
Eldarion's Avatar
So the error is caused by random garbage going into the program port?
I was able to fix it by just pressing Reset on the RC; I was more curious what the actual error meant.
-- Thomas Paine
-- Anonymous
Unread 25-01-2006, 00:41
Well, that's how ours was caused. We had three IFI techs looking at it (we were in line at nationals) and they said that it is a special diagnostic mode. While we were downloading the code, apparently our cable degraded the signal such that the master microprocessor thought that we wanted diagnostic mode, and then it got stuck in it somehow (it wasn't entirely clear to me). Very strange.
Unread 25-01-2006, 00:46
Eldarion's Avatar
That's kind of cool! I wonder how you purposefully put it into diagnostic mode, and what kind of information you can get...
Thanks!
-- Thomas Paine
-- Anonymous
Unread 25-01-2006, 01:29
For obvious reasons, the guys wouldn't tell us
Unread 25-01-2006, 13:52
This sounds like a question for Innovation FIRST. I doubt anyone here knows the answer. You can either try their forum: http://www.ifirobotics.com/forum/ or contact them directly http://www.ifirobotics.com/contact.shtml.
Unread 25-01-2006, 18:23
devicenull devicenull is offline
Robot? We need a robot?
Rookie Year: 1234
devicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nice
It's not actually an error code. It's apparently a internal self-test.. It's caused by.. holding the program button down too long. Basically let go once you see Program status go orange.
I don't think IFI ever told us what it all means, but it's not an error at all (every RC I've used does it)
Although.. ask them anyway, it seems like it could be useful
Intermittent Code Error Plloyd Programming 9 09-04-2005 21:37
MPLink Error cloudago Programming 2 01-02-2005 23:00
PHP and Wiki Error Venkatesh Website Design/Showcase 2 24-07-2004 15:51
EMERGENCY! EPROM FULL error?!? CHSguard72 Programming 2 05-03-2003 20:51
is anyone wanting a lot of lights (decorative) on the robot? archiver 2001 5 24-06-2002 00:09
