Go to Post Woody is wearing flippers... 2014 WATER GAME! - Team23pitboss [more]
Unread 24-01-2006, 09:14
naor52 naor52 is offline
FRC #1578
naor52 is an unknown quantity at this point
section 'InterruptVectorLow' type is non-overlay (was: HELP HELP HELP!!!!!)
i have an error and i don't know why
i install the serial_ports code as the read me tell me to do
and i got this error:
" MPLINK 3.90, Linker
Copyright (c) 2004 Microchip Technology Inc.
Error - section 'InterruptVectorLow' type is non-overlay and absolute but occurs in more than one input file.
Errors : 1 "
Unread 24-01-2006, 09:39
DKolberg DKolberg is offline
Mentor Iron Giants
AKA: David Kolberg
FRC #5069 (Iron Giants)
DKolberg has a spectacular aura aboutDKolberg has a spectacular aura about
Re: section 'InterruptVectorLow' type is non-overlay (was: HELP HELP HELP!!!!!)
Errors : 1 "
From the description of the error, I would search the project for interruptvectorlow and only use it in one file. figure out which file is best to use it in and remove it from the others.
Dave
David Kolberg
2014- Mentor Iron Giants 5069
2004-2010 Coach SBotz Team 1327
2000-2003 Mentor Team 135
2016 St. Joe District Event Winner
2009 WFA Boilermaker
2008 Driving Tomorrow's Technology
2005 Innovation in Control
2005 IRI Spirit of Indiana
Unread 24-01-2006, 10:07
FRC #1578
i installed the serial_ports code like the read me said and he gives me that error
Unread 24-01-2006, 10:18
Mentor Iron Giants
AKA: David Kolberg
Which files did you copy into your project?
David Kolberg
Unread 24-01-2006, 10:37
FRC #1578
i insert the file serial_ports.c, serial_ports.h
and i think the error is in the user_routines_fast.c in fanction
void InterruptHandlerLow ()
if you could give your uuser_routines_fast.c wich works so add it
Unread 24-01-2006, 10:41
Mentor Iron Giants
AKA: David Kolberg
The InterruptVectorLow is defined in the user_routines_fast.c file. It should not be defined in any other file and you only have one user_routines_fast file (did not rename the file). The directions in the read me file indicate that you should copy the code for the interrupt vector into your file.
If you are using the camera, I would suggest you start with that code as the baseline and copy that directory into a new directory and add your user code to that version. It already has all of Kevin's files integrated in so is a good starting point. It is usually easier to create your own c and header file for your code and just call it from the main code. This adds some overhead for the additional call but allows updating to newer base code a lot easier.
Dave
David Kolberg
Unread 24-01-2006, 11:45
I get the "non-overlay and absolute but occurs in more than one input file" error when moving project files between directories. When it happens, the solution is to do a full "clean" build, using the Make All menu choice.
Unread 24-01-2006, 12:18
FRC #1578
i did what Alan Anderson told and now the problem is :
MPLINK 3.90, Linker
Error - section '.code_eeprom.o' can not fit the section. Section '.code_eeprom.o' length=0x000001a4
Errors : 1
Unread 24-01-2006, 14:19
Congratulations, you just hit the limit of available program space. The "can not fit the section" error means you have too much software to fit in your robot controller.
Are you using a 2006 RC? If so, have you told MPLAB that you're using a 2006 RC (by choosing the proper PIC from the device list)? Have you corrected any older #include statements that refer to the smaller 2004/2005 controller's PIC?
Unread 24-01-2006, 16:52
FRC #1578
I am using 2006 RC but i didn't choose the proper PIC from the device list and didn't
how I do that?
thank you Alan
Unread 24-01-2006, 21:37
From the Configure menu, choose Select Device..., make sure that PIC18F8722 is selected in the Device: field, then press OK.
Look at the #include statements to make sure that p18f8520.h isn't still being referenced by any of your files. If you find any, change it to p18f8722.h instead.
If neither of these was a problem, then you indeed have too much in your program to fit the new RC. We were warned in the kickoff presentation to watch out for that.
Unread 25-01-2006, 09:08
FRC #1578
Still doesent work...
It compiles without errors but I cant write a thing! It just doesent let me
type in the program. The keyboard is alright because it writes in other
programs like in this site
please help!!!
Unread 25-01-2006, 15:46
6600gt's Avatar
6600gt 6600gt is offline
AKA: Lohit
FRC #0226 (Hammerhead)
6600gt is a jewel in the rough6600gt is a jewel in the rough6600gt is a jewel in the rough
Re: Still doesent work...
please help!!!
Open up the file you can't type in in MPLAB and on the page right click and open properties and the Protect Read Only Files will be checked, uncheck it.
Unread 15-02-2007, 21:31
chapmatr's Avatar
chapmatr chapmatr is offline
Zippidy bling-zap whippy-wog snizin
AKA: Travis (Lead Programmer)
FRC #1676 (Pascack Pioneers)
Team Role: Driver
chapmatr is an unknown quantity at this point
Send a message via AIM to chapmatr
Yeah, we're getting the same problem trying to convert our camera stuff into easyC, can anyone tell us what to do? we can't do a make clean because we don't know how to directly access the compiler.
Did you know that 87% of all online statiscs are made up?
Unread 24-02-2007, 01:19
JimGRobot JimGRobot is offline
AKA: Jim
FRC #1388 (Eagle Robotics)
JimGRobot is just really niceJimGRobot is just really niceJimGRobot is just really niceJimGRobot is just really nice
I got this error after making a bunch of changes, and one change was copying the latest FRC_MASTER_V13.BIN file into the project directory, and leaving the old version, FRC_MASTER_V12.BIN, there too.
When I deleted the version 12 file, the problem went away. However, I was making other changes at the time, and this might not be what fixed it.
Good luck,
Jim
Error - section 'UTIL_LIB' can not fit the section. Section 'UTIL_LIB' length=0x00000 BookerT Programming 13 27-01-2005 09:49
Error - section 'UTIL_LIB' can not fit the section. Section 'UTIL_LIB' length=0x00000 BookerT Programming 0 25-01-2005 19:17
Linking Errors: "section '????' can not fit the section. ..." Astronouth7303 Programming 3 16-01-2005 21:36
PSATs Back Yan Wang Chit-Chat 23 20-12-2003 13:16
Game Idea archiver 2000 3 23-06-2002 23:27
