Go to Post The point is that while having the abiltity to find information in a variety of reference sources is a useful skill, it does not replace a good, complete, fundamental knowledge of your subject material. - dlavery [more]
Unread 25-01-2006, 12:45
AKA: Dr. Brooks
no team (WRRF)
Re: Measuring Muzzle Velocity
Originally Posted by Don Rotolo
Very cool.
We measure muzzle velocity by shooting the ball through a light beam (an LED and sensor pair, spaced 8" apart) and measuring the time it takes for a 6.875" ball to cross it. We used a storage oscilloscope to measure the time, but we're looking for a better way of measuring the time, on the order of 15 milliseconds.
Don
Use one of the timers on the RC set up in 16 bit mode and your optical sensors set up to interrupt the RC on digital inputs 1 and 2. Assuming that digital input 1 is the start for the timer, when this interrupt comes through zero the timer. When the second interrupt on digital input 2 comes through read the timer into a variable available to code running in the packet loop. Have a look at Kevin's interrupt template code, and pay careful attention to his comments on how to read and write the timer correctly in 16 bit mode.
By suitably adjusting the pre-scaler for the timer your granularity can be 100ns, 200ns, 400ns or 800ns. Assuming a 16 bit timer and the 800ns clock tick you can measure up to 52.4 milliseconds with very high precision.
Have fun,
Eugene
How will FIRST measure muzzle velocity? ted bell Rules/Strategy 68 28-01-2006 15:44
pneumatic launch velocity Keeler836 Pneumatics 23 16-01-2006 23:23
Measuring projectile poof balls mechanicalbrain Rules/Strategy 11 08-01-2006 21:36
Measuring a Pulse Width MikeDubreuil Programming 22 21-07-2005 10:22
SHU measuring stick sanddrag Rules/Strategy 13 08-01-2003 21:23
